Javascript API Print webmap Sample Question
2832
06-04-2014 05:53 AM
MichaelVolz
Esteemed Contributor
To All Javascript API Developers:
https://developers.arcgis.com/javascript/jssamples/widget_print_webmap.html
The above link shows an ESRI sample of using the Print Dijit to print a webmap.
I am confused about the line of code below:
app.webmapId = "8315cf7d20f0484e869c4791f70f4f15";
Is this webmapId required here because the sample is printing a webmap from ArcGIS.com?
Can I remove this line of code if I want to use my own custom print service in this sample?
ScottGunn
Yep, that is the "Print webmap" dijit and it is printing an AGO webmap.
To use your own services, you would need to use the Print widget:
Sample:
https://developers.arcgis.com/javascript/jssamples/widget_print.html
API reference:
https://developers.arcgis.com/javascript/jsapi/print-amd.html
You can also use the Print Task:
https://developers.arcgis.com/javascript/jsapi/printtask-amd.html
if you want more control over your printing.
If you use the Print widget or Print Task, there are parameters in each method that would need to be set to your print service URL.
