Simple Map Viewer template
1714
06-02-2014 02:13 PM
MichaelThompson2
I downloaded the Simple Map Viewer template and have been poking around in the html and css files. I can't seem to figure out where I need to be making changes in order to see them in the application with regard to layout, padding, colors, etc.
In the html file there is this bit
[HTML]    <!--Use protocol relative urls that way if the browser is viewing the page via HTTPS the js/css file will be requested using the HTTPS protocol-->
    <link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/3.9/js/dojo/dijit/themes/tundra/tundra.css">
    <link rel="stylesheet"  href="https://community.esri.com//js.arcgis.com/3.9/js/esri/css/esri.css">
    <!--Load any application specific styles-->
    <link rel="stylesheet" href="css/main.css">[/HTML]
and I feel like this is an important area but I only see changes when I change the css file on the last line. The template comes with a few css files but not all of them change anything. the iPhone.css and the pavement.css files make some pretty big changes, but then when I go to edit those css files, those changes don't show up on the page. Am I trying to edit in the right places?
KenBuja
MVP Esteemed Contributor
Have you included the references to these other css files in the HTML code? That would be something like
<link rel="stylesheet" href="css/iPhone.css">
<link rel="stylesheet" href="css/pavement.css">
MichaelThompson2
I guess I don't know exactly how stylesheets work. You can reference more than one and they won't conflict?
LisCollins
For changing the layout, have you tired looking into the layout.js file in the javascript folder?
JeffJacobson
It is very common for a web page to use more than one CSS file. A rule in later stylesheet (referenced lower in the HTML document) can override a rule set by an earlier one.
