using dot density renderer with dynamic layer
4276
06-02-2014 11:54 AM
DavidMarquardt
I'm looking to make a dot density map with a DynamicMapServiceLayer (dynamic layer).  While I've seen dynamic layers used in other rendering types (such as Class Breaks), I haven't seen one for dot density (the examples I have seen use a FeatureLayer instead).  I've been testing a potential solution below.  The following script is based on
https://developers.arcgis.com/javascript/jssamples/renderer_dynamic_layer_change_attribute.html.  The only change I made was to swap out the classbreaks function for a dot density function (to create a dot density renderer). My questions are:
Have you seen any examples using a dot density renderer with a dynamic Layer?
The Classbreaks function uses a generateRendererTask when setting up the LayerDrawingOptions.  Does the dot density use the same Task?
Thank you for your time,
David
       function getData() {
          domStyle.set("loading", "visibility", "visible");
          dotDensity();
        function dotDensity() {
          selectField = registry.byId("fieldNames").get("value") || "POP2007";
          console.log(selectField);
          var renderer = new DotDensityRenderer({
            fields: [{
              color: new Color("#CC8800")
            dotValue: 3200,
            dotSize: 1
          applyRenderer(renderer);  // this is one part I'm not sure of.
                                    // do I need to put this in a GenerateRendererTask?
        function applyRenderer(renderer) {
          // dynamic layer stuff
          var optionsArray = [];
          var drawingOptions = new LayerDrawingOptions();
          drawingOptions.renderer = renderer;
          // set the drawing options for the relevant layer
          // optionsArray index corresponds to layer index in the map service
          optionsArray[2] = drawingOptions;
          app.map.getLayer("us_counties").setLayerDrawingOptions(optionsArray);
          app.map.getLayer("us_counties").show();
          // create the legend if it doesn't exist
          if ( ! app.hasOwnProperty("legend") ) {
            createLegend();
nita14
implement FeatureLayer instead of Dynamic Map Service Layer.
Below you find my code:
var postalDemoRen = new DotDensityRenderer({
  fields: [{
   color: new Color([52, 114, 53])
  dotValue: 10,
  dotSize: 2
var postalDemo = new FeatureLayer(".../MapServer/107",{
  mode: FeatureLayer.MODE_ONDEMAND,
  outFields: ["*"]
  postalDemo.setRenderer(postalDemoRen);
Regards,
Adm
DavidMarquardt
Adam,
Thanks so much!  I'm specifically looking to use it with dynamic map service, because I usually am working with many records (300 + county polygons). These tend to slow down or become unusable as a feature service.
David
RobertScheitlin__GISP
Kelly Hutchins​ Can you confirm if the DotDensity renderer is a supported renderer for use with dynamic layers?
nita14
As far as I know, DotDensity and ScaleDependentRenderer are not supported for Dynamic Map Services.
It slows dawn, because the app actually download the requested data. I think you have two options:
     - simplify cunties polygons using GeometryService and generalize method (not tested, could also take a while to process depending on your data)
     - make a copy of original data (if possible), make geometry and attribute generalization in ArcGIS, then share as feature service using AGOL
Hope this helps a bit,
Regards,
Adam
