Displaying feature layer symbol in a custom table of contents
1771
06-02-2014 03:45 AM
ChristianDebono
I have built a custom table of contents similar  to the TOC widget http://www.arcgis.com/home/item.html?id=9b6280a6bfb0430f8d1ebc969276b109. The only problem I have is how I am going to display the feature layer icon as the legend.
function generateLegend(listOfLayers){
 require(["esri/layers/FeatureLayer", "dojo/on"],
 function (FeatureLayer, on) {
  //initialazing the feature layer and adding them in a list and on the map
  var layerList = [];
  for(var i=0; i < listOfLayers.length; i++){
   layerList = new FeatureLayer(urlList);
   map.addLayer(layerList);
  for(var i = 0; i < nameList.length; i++){
   var layerId =  "Layer" + i; //id for the layer
   var layerPostid = "teste" + i; //id for the layer
                        //I also want to display the icon here
   //html list to be dispalyed on the browser
   layerDisplay += "<li id='" + layerPostid + "'><input type='checkbox' checked='yes' id=" + layerId + ">" + legendIcon + "<a href='#' id=" + layerId + " onclick='return false;'>" + nameList + "</a><ul><li><div class='slider'></div></li></ul></li>";
  layerDisplay += "</ul>";
  //displaying the legend
  $("#tocLegend").html(layerDisplay);
Any ideas how I could achieve this please?
by Anonymous User
Not applicable
You can use esri/request from the JavaScript API to get legend image urls from the server: ArcGIS REST API‌ documentation gives more information. Sorry I don't have time to post code but that should help get you started.
by Anonymous User
Not applicable
So here is some code...sorry not sure how to format in the new forums:
function legendRequest(mapServerURL, thisLayer2) {
    //mapserverURL is something like "http://www.server.com/arcgis/rest/services/myMap/MapServer"
    var fetchURL = mapServerURL + '/legend/';
    // Use server requests to get the legend symbol image urls
    var legendRequestPromise = esriRequest({
               url : fetchURL,
               content : {
               f : "json"
               handleAs : "json"
   legendRequestPromise.then(function(jsonResults) {
             console.log(jsonResults);
            // If you look at the JSON response in the console you can see where image urls are given
            // layers --> 0 -->legend --> 0 -->url
            // Then use these to construct the URL to place in your html divs (format: mapserverURL/layerID/images/imageURL)
   }, function(error) {
                 console.log("Error: ", error.message);
