Cant get the execute query task to run
1246
05-28-2014 12:04 PM
DaveTaylor
I want to have a map load as soon as the page is open...it will plot all 1000+ points on the map...then at the top of the page there is a text box where the user can filter the map. Once the button is clicked it should kick off a query task and query the layer only showing those that were typed in the text box. I keep getting the error executeQueryTask is not defined...I know I am missing something simple but cant figure it out. My code is below:
function init() {
  queryTask = new esri.tasks.QueryTask("https://myserver/Locations/MapServer/0");
        //initialize query
        query = new Query();
        query.returnGeometry = true;
        query.outFields = ["*"];
  function executeQueryTask() {
    //set query based on what user typed in for population;
    query.where = "QUALIFICAT IN " + QUALIFICAT;
    //execute query
    queryTask.execute(query,showResults);
   function showResults(featureSet) {
    //remove all graphics on the maps graphics layer
    map.graphics.clear();
    //Performance enhancer - assign featureSet array to a single variable.
    var resultFeatures = featureSet.features;
    //Loop through each feature returned
    for (var i=0, il=resultFeatures.length; i<il; i++) {
      //Get the current feature from the featureSet.
      //Feature is a graphic
      var graphic = resultFeatures;
      graphic.setSymbol(symbol);
      //Set the infoTemplate.
      graphic.setInfoTemplate(infoTemplate);
      //Add graphic to the map graphics layer.
      map.graphics.add(graphic);
<body>
    <br/>
    Qualification Type: <input type="text" id="QUALIFICAT" value="OT" />
    <input type="button" value="Get Details" onclick="executeQueryTask(dojo.byId('QUALIFICAT').value);" />
  <div id="map"></div>
  <div id="footer"
  data-dojo-TYPE="dijit.layout.ContentPane"
  data-dojo-props="region:'bottom'">
  </div>
JeffPace
you are calling executeQueryTask(variable)
but you have no function executeQueryTask(variable), you only have executeQueryTask() which takes no arguments
DaveTaylor
Sorry I am not following.
I must be overlooking something...
ManishkumarPatel
Hi Dave,
The function you are trying to call takes one parameter
But the function you have in the code snippet does not take any parameter
    //execute query
Instead try to change to below:
function executeQueryTask(QUALIFICAT) {
    //execute query
Hope this helps.
Regards,
Manish
