TOC Toolkit documentation?
2449
9
05-27-2014 05:01 AM
CharlesGant
Does anyone know where I can find the TOC toolkit documentation?  The link to the actual download does not indicate such, and I could not find anything in the downloaded tarball.  I'm particularly interested in the options/arguments that I can apply to each layer. I have the TOC working, I just need to be able to setup the icon, opacity, collapse, etc.....
Thanks in advance!
CharlesGant
http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/latest/docs/toc/reference.html
Jeff,
Do you know how to set all the layers to "un-check" by default?  I have the layers hidden, so they don't show, but the boxes in the TOC are check and for them to work you have to "un-check" and "re-check" them.
Thanks!
JeffPace
mine obey visibility.  Make sure you arent grouping layers in your mapservice, TOC can't handle groups
CharlesGant
Jeff, As you can see they are not grouped.  When you say "obey visibility", are you setting the layers invisible when you declare, or like the method I'm using below?
   //Use the ImageParameters to set the invisible layers in the map service during ArcGISDynamicMapServiceLayer construction.
   var imageParameters = new ImageParameters();
   imageParameters.layerIds = [0,1];
   imageParameters.layerOption = ImageParameters.LAYER_OPTION_INCLUDE;
   //can also be: LAYER_OPTION_EXCLUDE, LAYER_OPTION_HIDE, LAYER_OPTION_INCLUDE
   //Takes a URL to a non cached map service.
   var dynamicMapServiceLayer0 = new ArcGISDynamicMapServiceLayer("http://atlas.resources.ca.gov/ArcGIS/rest/services/Atmosphere_Climate/RIDGE_Precip_Radar/MapServer/", {
      "opacity" : 0.5,"imageParameters":imageParameters});
   var dynamicMapServiceLayer1 = new ArcGISDynamicMapServiceLayer("http://gisdev.srh.noaa.gov/arcgis/rest/services/GSP/gffg/MapServer", {
   map.addLayer(dynamicMapServiceLayer0);
   map.addLayer(dynamicMapServiceLayer1);
PeterHoffman
I am new to JavaScript coding and just found this thread. How do I download the toc code?
JonathanUihlein
Hi Peter, there was a link posted earlier in this thread.
https://code.google.com/p/gmaps-utility-gis/
PeterHoffman
I found the link but it leads to a folder structure of the files. Is there a zip file or equiv.?
JonathanUihlein
Using Google (searched for: esri toc widget)... first link. (http://www.arcgis.com/home/item.html?id=9b6280a6bfb0430f8d1ebc969276b109)
Scroll down. There's a zip file link there.
Also, if you've never used GIT or a version-control system, you're missing out on some good stuff.
PeterHoffman
Yep, that's what I need, thanks for quick reply.
I am starting to move my flash based apps to javascript so I am looking for widgets, etc.
