JavaScript Optimizer (jso.arcgis.com)
1848
05-20-2014 08:11 AM
ScottGunn
Hi all,
The JS Optimizer at http://jso.arcgis.com was recently released.  Has anyone had a chance to try it yet?
I compiled a list of modules that my app uses in a plain text file and built it through the system.  Extracted it to my server, included the script tag like so:
<script src="js/dist/dojo/dojo.js" data-dojo-config="async: true"></script>
But it does not load.  The console reports the following on load:
/js/dist/dojo/fx/Toggler.js 404 (Not Found)  on line 26 of dojo.js
The problem is Toggler.js is in my module list on the build (it's a dep) so I'm not sure what's going on...Could it be that I have a custom dojoConfig var defined before loading dojo.js? It has some custom packages, among them the latest version of dgrid.
Very nice tool, looking forward to enjoying the benefits of a compact API on my app.
derekswingley1
Thanks. Your dojoConfig looks good, it's not causing this.
We should probably be bundling this module with builds automatically. Until then, please add dojo/fx/Toggler to your module list (it's not in the one you posted).
derekswingley1
Could be related to your dojoConfig. Can you post that as well as your module list that you uploaded?
ScottGunn
Hi Derek,
Sure, here is my dojoconfig (defined before dojo.js is loaded):
<script type="text/javascript" >
 var dojoConfig = {
  async: true,
        packages: [
    { "name": "js",
   "location": location.pathname.replace(/\/[^/]+$/, "")+'js/'
    { "name": "widgets",
   "location": location.pathname.replace(/\/[^/]+$/, "")+'js/widgets/'
    { "name": "dgrid",
   "location": location.pathname.replace(/\/[^/]+$/, "")+'js/dgrid/'
</script>
I am using AMD so have some custom widgets, etc. in /js and /js/widgets.
Here's my line to load dojo.js (I changed it from myHostname/js/dist to myHostname/dist.  I have also tried to take out the async:true w/ the same results:
<script src="dist/dojo/dojo.js" data-dojo-config="async: true"></script>
Here's my module list (with some duplicates that the JSO appears to remove):
"esri/dijit/PopupTemplate",
"esri/InfoTemplate",
"esri/symbols/SimpleMarkerSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/symbols/Font",
"dojo/_base/Color",
"esri/map",
"dojo/parser",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/layers/ArcGISTiledMapServiceLayer",
"esri/geometry/Extent",
"esri/SpatialReference",
"esri/dijit/Popup",
"dojo/_base/array",
"dojo/dom-construct",
"dojo/dom-class",
"dojo/on",
"esri/tasks/IdentifyTask",
"esri/tasks/IdentifyParameters",
"dojo/_base/array",
"dojo/_base/Deferred",
"dojo/DeferredList",
"dojo/_base/declare",
"dojo/on",
"esri/tasks/query",
"dojo/store/Memory",
"esri/tasks/QueryTask",
"dojo/_base/array",
"dojo/domReady!",
"esri/tasks/query",
"esri/graphic",
"esri/symbols/SimpleFillSymbol",
"dojo/_base/Color",
"dojo/domReady!",
"dijit/form/HorizontalSlider",
"dojo/domReady!",
"esri/tasks/query",
"dojo/_base/array",
"esri/dijit/BasemapGallery",
"esri/toolbars/draw",
"esri/symbols/CartographicLineSymbol",
"esri/graphic",
"esri/Color",
"dojo/dom",
"dojo/on",
"esri/geometry/Point",
"esri/geometry/webMercatorUtils",
"esri/graphic",
"dojo/on",
"dojo/on",
"esri/tasks/GeometryService",
"esri/layers/GraphicsLayer",
"esri/geometry/Polyline",
"esri/symbols/TextSymbol",
"esri/tasks/DistanceParameters",
"esri/tasks/AreasAndLengthsParameters",
"esri/graphic",
"dojo/_base/array",
"esri/toolbars/navigation",
"esri/tasks/Geoprocessor",
"esri/request",
"esri/tasks/DataFile",
"dojo/dom",
"dojo/_base/array",
"dojox/data/CsvStore",
"esri/geometry/Multipoint",
"esri/layers/FeatureLayer",
"dojo/on",
"dojo/_base/lang",
"esri/tasks/PrintTask",
"esri/tasks/PrintParameters",
"esri/tasks/PrintTemplate",
"esri/dijit/Scalebar"
Thanks!
derekswingley1
ScottGunn
Thanks, that did the trick!
