Finding maximum value between multiple rasters
5419
05-14-2014 05:10 AM
BruceBurwell
Hello
I think this should be an easy problem. I have multiple rasters that I would like to assess on a pixel by pixel basis and create a new raster of just the maximum values. How would I accomplish this? I tried using the Local Tool Highest Position but that isn't what I wanted.
Bruce Burwell
Saudi Aramco
JimCousins
There may be a better way to do this, but I would use the raster calculator with a series of nested CON() statements, using > to filter for the maximum values.
Best Regards,
Jim
RobertBorchert
Honored Contributor
Using the From Raster Tools under Conversion Tools in Toolbox you can export your rasters as polygons or points or polylines.  The exported point will retain the raster cell value.
Hello
Bruce Burwell
Saudi Aramco
NeilAyres
Wouldn't SA tools / Local / Cell Statistics do what you need?
Good luck, Neil
