AutoPopulate field
11587
17
05-12-2014 12:47 PM
NickErlacker
When one is editing a Feature Layer in the JavaScript viewer and they add a new feature. Is there a way to auto populate a particular field?
I know you can set a default value in the database for that field. But I want the value to be based off of the Day and time in one string of numbers. I read that you can use the before-apply-edits event? How ? is there an example out there that shows this ? Or  any example that shows how to auto populate a field with the editor widget?
Thank you
Nick
JeffPace
I do this to autopopulate the editor field with the logged in user name
(i use the attribute Inspector)
so the "USER_" field, which is listed as a noneditableField (so they cant override it), gets populated
var attInspector = new AttributeInspector({             layerInfos:layerInfos           }, "attributesDiv");            attInspector.on("attribute-change", function(evt) {                var feature = evt.feature; //keep all fields the same from the input                feature.attributes[evt.fieldName] = evt.fieldValue; //override the USER_ field with the userId from the credentials object                feature.attributes.USER_ = esri.id.credentials[0].userId; //apply attribute update                feature.getLayer().applyEdits(null, [feature], null); //refresh to show the 'behind the scenes' edit                attInspector.refresh();           });
JeffPace
NickErlacker
Thank you I see make sense.
After looking at it I tried using the DOM and used on a update event
on(editLayer, 'update', function (evt) {
                               populateNumber();
 function populateNumber(){
 var input = document.getElementById('dijit_form_TextBox_0');
 if(input.value.length == 0)
    input.value = "Empty";
It takes the first input in the Editior widget and assigns it an Empty if it is blank
Thank you for your post
HectorChapa
This is exactly what I am trying to do. I am learning javascript api but I done couple of great things with it but I need help.
This is my code that I am using for the map. I dont know how to implemented on my feature class I want to auto populate what
ever I wanted to say.
Could you please help me to add this to my feature class check out my code let me know how could I implement this.
require([
        "esri/map",
        "esri/tasks/GeometryService",
        "esri/toolbars/edit",
   "esri/graphic",
        "esri/Color",
        "esri/dijit/HomeButton",
        "esri/dijit/BasemapGallery",
        "esri/dijit/LocateButton",
  "esri/dijit/Geocoder",
       "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/layers/FeatureLayer",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/dijit/editing/Editor",
        "esri/dijit/editing/TemplatePicker",
        "esri/config",
        "dojo/i18n!esri/nls/jsapi",
  "dojo/on",
        "dojo/_base/array", "dojo/parser", "dojo/keys",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
        "dojo/domReady!"
      ], function(
        Map, GeometryService, Edit,
  Graphic, Color,
        HomeButton, BasemapGallery, LocateButton,
  Geocoder,
        ArcGISDynamicMapServiceLayer, FeatureLayer,
        SimpleMarkerSymbol, SimpleLineSymbol,
        Editor, TemplatePicker,
        esriConfig, jsapiBundle,
  on,
        arrayUtils, parser, keys
        parser.parse();
        //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications.
        esriConfig.defaults.geometryService = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
        map = new Map("map", {
          basemap: "streets",
          center: [-98.185272, 26.282376],
          logo: false,
          sliderStyle: 'large',
          zoom: 9,
         var home = new HomeButton({
          map: map
        }, "HomeButton");
        home.startup();
         geoLocate = new LocateButton({
        map: map
      }, "LocateButton");
      geoLocate.startup();
   var geocoder = new Geocoder({
          arcgisGeocoder: false,
          autoComplete: true,
    zoomScale:1000,
          geocoders: [ {
            url: "http://maps.lrgvdc911.org:6080/arcgis/rest/services/Public_Outreach/SDE_ADDRESS_POINTS_130917_Create2/GeocodeServer",
            placeholder: "Locate",
            outFields: "*",
            singleLineFieldName: "SingleLine"
          map: map
        }, "search");
     geocoder.on('select', function (candidate) {
       for(var i = 0; i< 20; i++)
          var geom = candidate.result.feature.geometry;
          var symbol = new SimpleMarkerSymbol();
          symbol.setStyle(SimpleMarkerSymbol.STYLE_CIRCLE);
          symbol.setColor(new Color([155, 0, 61, 0.75]));
          var graphic = new Graphic(geom, symbol);
          map.graphics.clear();
          map.graphics.add(graphic);
    geocoder.on('clear', function(){
        var basemapGallery = new BasemapGallery({
          showArcGISBasemaps: true,
          map: map
        }, "basemapGallery");
        basemapGallery.startup();
        basemapGallery.on("error", function(msg) {
          console.log("basemap gallery error:  ", msg);
        map.on("layers-add-result", initEditor);
        //add boundaries and place names
        var dynamic = new ArcGISDynamicMapServiceLayer("http://maps.lrgvdc911.org:6080/arcgis/rest/services/STEAR/STEAR_DYNAMIC/MapServer");
        map.addLayer(dynamic);
        var events = new FeatureLayer("http://maps.lrgvdc911.org:6080/arcgis/rest/services/Public_Outreach/EVENTS/FeatureServer/0",{
          mode: FeatureLayer.MODE_ONDEMAND,
          outFields: ['EVENT_NAME', 'date','address', 'psap']
        map.addLayers([events]);
        function initEditor(evt) {
          var templateLayers = arrayUtils.map(evt.layers, function(result){
            return result.layer;
          var templatePicker = new TemplatePicker({
            featureLayers: templateLayers,
            grouping: true,
            rows: "auto",
            columns: 1
          }, "draggable");
          templatePicker.startup();
          var layers = arrayUtils.map(evt.layers, function(result) {
            return { featureLayer: result.layer };
          var settings = {
            map: map,
            templatePicker: templatePicker,
            layerInfos: layers,
            toolbarVisible: true,
            createOptions: {
              polylineDrawTools:[ Editor.CREATE_TOOL_FREEHAND_POLYLINE ],
              polygonDrawTools: [ Editor.CREATE_TOOL_FREEHAND_POLYGON,
                Editor.CREATE_TOOL_CIRCLE,
                Editor.CREATE_TOOL_TRIANGLE,
                Editor.CREATE_TOOL_RECTANGLE
            toolbarOptions: {
              reshapeVisible: true
          var params = {settings: settings};
          var myEditor = new Editor(params,'editorDiv');
          //define snapping options
            SimpleMarkerSymbol.STYLE_CROSS,
            15,
            new SimpleLineSymbol(
              SimpleLineSymbol.STYLE_SOLID,
              new Color([255, 0, 0, 0.5]),
              5
            null
          map.enableSnapping({
            snapPointSymbol: symbol,
            tolerance: 20,
            snapKey: keys.ALT
          myEditor.startup();
NickErlacker
I am not sure what you are asking? but I used the event for the feature class called 'update' to trigger the function as seen in my previous post to run and get the first id in the editior infowindow and enter in a value.
Is this what you are asking?
HectorChapa
I have a feature class that I put points on the map. When I put a point on the map a info window appears to input the values.
One of the fields from that info window I would like to autopopulate that information that is what I am asking. But the problem is that I have no clue how to do it. Could you help me.
HectorChapa
Are you using template picker. if yes could I see your full snippet of code.
MatthewGoulet1
Hi, Hector. I would love to see that code! I am struggling w/ the same problem as above.
HectorChapa
Hey Matthew what code do you need.
I have to code to autoPopulate a field.
MatthewGoulet1
Yes, it's the code to auto-populate a field.
