AutoPopulate field
11666
17
05-12-2014 12:47 PM
NickErlacker
When one is editing a Feature Layer in the JavaScript viewer and they add a new feature. Is there a way to auto populate a particular field?
I know you can set a default value in the database for that field. But I want the value to be based off of the Day and time in one string of numbers. I read that you can use the before-apply-edits event? How ? is there an example out there that shows this ? Or  any example that shows how to auto populate a field with the editor widget?
Thank you
Nick
HectorChapa
Do you have teamviewer?
MatthewGoulet1
No, I don’t unfortunately.
HectorChapa
This is what I did.
map.addLayers([events]);
  function initEditor(evt) {
  var featureLayer = evt.layers[0].layer;
  dojo.connect(featureLayer,'onBeforeApplyEdits',function(adds,deletes,updates){
  dojo.forEach(adds,function(add){
  if(add.attributes['psap'] === null){
  add.attributes['psap'] = psap;
HectorChapa
here is my email if you need more help [email protected]
Email me and I give you my work number so you can see what I did.
MatthewGoulet1
Hector, you solution worked great! Thanks a lot.
The only thing that tripped me up was the placement of the code. In my case, the .connect functions were not firing until I moved them out of initEditor(evt) function. I put the onBeforeApplyEdits hook just before the .addLayers calls, and it worked perfectly.
Thanks again!
HectorChapa
I am glad I could help. I have develop many applications and I created libraries for many of the questions I ask and I have solved. Please email me I provided my contact information I am glad to help in the future.
LindaDunklee
Can someone clarify inside of the sample provided where Hector's code goes?  This would be hugely helpful!
Thanks!
HectorChapa
I am adding a updated version of the code using AMD for anyone that is interested using. The one I provided was Legacy Dojo using dojo.connects.
I just wrote this five minutes ago. With this one you don't have to worry were the listener goes inside the function. This is a working exmaple.
The way it works once you click on the map to add a point then before apply edits executes and in there you tell javascript to edit a particular field automatic. It auto populates that field. Look for the listener that say before-apply-edits and I apply it to a particular attribute.
My Contact information:
email: [email protected]
phone: 956-682-3481 ext. 143
<!DOCTYPE html>
<html>
  <head>
    <title>Edit rivers and waterbodies</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.16/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/css/esri.css">
    <style>
      html,body{height:100%;width:100%;margin:0;overflow:hidden;}
      #map{
        padding:0;
      #header{
        font-size: 1.1em;
        font-family: sans-serif;
        padding-left: 1em;
        padding-top:4px;
        color:#660000;
      .templatePicker {
        border: none;
      .dj_ie .infowindow .window .top .right .user .content { position: relative; }
      .dj_ie .simpleInfoWindow .content { position: relative; }
    </style>
    <script src="https://js.arcgis.com/3.16/"></script>
    <script>
      var map;
      require([
        "esri/map",
        "esri/tasks/GeometryService",
        "esri/layers/ArcGISTiledMapServiceLayer",
        "esri/layers/FeatureLayer",
        "esri/Color",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/dijit/editing/Editor",
        "esri/dijit/editing/TemplatePicker",
        "esri/config",
        "dojo/i18n!esri/nls/jsapi",
        "dojo/_base/array", "dojo/parser", "dojo/keys",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
        "dojo/domReady!"
      ], function(
        Map, GeometryService,
        ArcGISTiledMapServiceLayer, FeatureLayer,
        Color, SimpleMarkerSymbol, SimpleLineSymbol,
        Editor, TemplatePicker,
        esriConfig, jsapiBundle,
        arrayUtils, parser, keys
        parser.parse();
        // snapping is enabled for this sample - change the tooltip to reflect this
        jsapiBundle.toolbars.draw.start = jsapiBundle.toolbars.draw.start +  "<br>Press <b>ALT</b> to enable snapping";
        // refer to "Using the Proxy Page" for more information:  https://developers.arcgis.com/javascript/3/jshelp/ags_proxy.html
        esriConfig.defaults.io.proxyUrl = "/proxy/";
        //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications.
        esriConfig.defaults.geometryService = new GeometryService("https://utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
        map = new Map("map", {
          basemap: "satellite",
          center: [-96.541, 38.351],
          zoom: 14,
          slider: false
        map.on("layers-add-result", initEditor);
        //add boundaries and place names
        var labels = new ArcGISTiledMapServiceLayer("https://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places/MapServer");
        map.addLayer(labels);
        var responsePoints = new FeatureLayer("https://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire/FeatureServer/0", {
          mode: FeatureLayer.MODE_ONDEMAND,
          outFields: ['*']
        var responsePolys = new FeatureLayer("https://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire/FeatureServer/2", {
          outFields: ['*']
        map.addLayers([responsePolys, responsePoints]);
        responsePoints.on("before-apply-edits", function(evt){
          console.log(evt);
          if(evt.adds[0])
            //Here you choose which attribute to update...
            evt.adds[0].attributes.description = "Testing this one out works fine";
          var templateLayers = arrayUtils.map(evt.layers, function(result){
            return result.layer;
          var templatePicker = new TemplatePicker({
            featureLayers: templateLayers,
            grouping: true,
            rows: "auto",
            columns: 3
          }, "templateDiv");
          templatePicker.startup();
          var layers = arrayUtils.map(evt.layers, function(result) {
            return { featureLayer: result.layer };
          var settings = {
            map: map,
            templatePicker: templatePicker,
            layerInfos: layers,
            toolbarVisible: true,
            createOptions: {
              polylineDrawTools:[ Editor.CREATE_TOOL_FREEHAND_POLYLINE ],
              polygonDrawTools: [ Editor.CREATE_TOOL_FREEHAND_POLYGON,
                Editor.CREATE_TOOL_CIRCLE,
                Editor.CREATE_TOOL_TRIANGLE,
                Editor.CREATE_TOOL_RECTANGLE
            toolbarOptions: {
              reshapeVisible: true
          var params = { settings: settings };
          var myEditor = new Editor(params, 'editorDiv');
          //define snapping options
          var symbol = new SimpleMarkerSymbol(
            SimpleMarkerSymbol.STYLE_CROSS,
            15,
            new SimpleLineSymbol(
              SimpleLineSymbol.STYLE_SOLID,
              new Color([255, 0, 0, 0.5]),
              5
            null
          map.enableSnapping({
            snapPointSymbol: symbol,
            tolerance: 20,
            snapKey: keys.ALT
          myEditor.startup();
    </script>
  </head>
  <body class="claro">
    <div id="main" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="height:width:100%;height:100%;">
      <div data-dojo-type="dijit/layout/ContentPane" id="header" data-dojo-props="region:'top'">
        Edit Hydrography
      </div>
      <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width: 300px;overflow:hidden;">
        <div id="templateDiv"></div>
        <div id="editorDiv"></div>
      </div>
      <div data-dojo-type="dijit/layout/ContentPane" id="map" data-dojo-props="region:'center'"></div>
    </div>
  </body>
</html>
