parser.parse();  is not a function
7986
05-09-2014 01:46 PM
GyeyoungChoi
Hi, I was integrating https://developers.arcgis.com/javascript/jssamples/find_map_datagrid.html
example into my map.
but I got:
TypeError: parser.parse is not a function
parser.parse();
here is my code below
var layerConfig = {
    urlTiled: "http://localhost:6080/arcgis/rest/services/v1/BaseMap42114/MapServer",
    urlInfo: "http://localhost:6080/arcgis/rest/services/aggiemap_beta/beta_MapInfo/MapServer",
    urlV1Info: "http://localhost:6080/arcgis/rest/services/v1/MapInfo/MapServer",
    qBldg: "http://localhost:6080/arcgis/rest/services/v1/MapInfo/MapServer/6"
var map;
require(["esri/map", "esri/layers/ArcGISTiledMapServiceLayer", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/dijit/HomeButton", "esri/tasks/FindTask",
    "esri/tasks/FindParameters", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
    "esri/Color", "dojo/on", "dojo/dom", "dijit/registry", "dojo/_base/array", "dojo/_base/connect", "dojox/grid/DataGrid", "dojo/data/ItemFileReadStore", "dijit/form/Button", "dojo/parser", "dojo/domReady!"],
function (Map, Tiled, ArcGISDynamicMapServiceLayer, HomeButton, FindTask, FindParameters, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol, Color, on, dom, registry, arrayUtils, connect, DataGrid, ItemFileReadStore, parser, Button) {
    var findTask, findParams;
    var map, center, zoom;
    var grid, store;
    parser.parse();
    registry.byId("search").on("click", doFind);
    var map = new Map("map", {
        center: [-96.345680, 30.612473],
        zoom: 16,
        basemap: "topo"
    var home = new HomeButton({
        map: map
    }, "HomeButton");
    home.startup();
    var tiled = new Tiled(layerConfig.urlTiled);
    var tamuInfo = new ArcGISDynamicMapServiceLayer(layerConfig.urlV1Info);
    map.addLayers([tiled, tamuInfo]);
    //search fnc
    //Create Find Task using the URL of the map service to search
    findTask = new FindTask(layerConfig.urlV1Info);
    map.on("load", function () {
        //Create the find parameters
        findParams = new FindParameters();
        findParams.returnGeometry = true;
        findParams.layerIds = [0];
        findParams.searchFields = ["MapDisplay"];
        findParams.outSpatialReference = map.spatialReference;
        console.log("find sr: ", findParams.outSpatialReference);
    function doFind() {
        //Set the search text to the value in the box
        findParams.searchText = dom.byId("searchField").value;
        findTask.execute(findParams, showResults);
    function showResults(results) {
        //This function works with an array of FindResult that the task returns
        map.graphics.clear();
        var symbol = new SimpleFillSymbol(
        SimpleFillSymbol.STYLE_SOLID,
        new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([98, 194, 204]), 2),
        new Color([98, 194, 204, 0.5]));
        //create array of attributes
        var items = arrayUtils.map(results, function (result) {
            var graphic = result.feature;
            graphic.setSymbol(symbol);
            map.graphics.add(graphic);
            return result.feature.attributes;
        //Create data object to be used in store
        var data = {
            identifier: "PARCELID", //This field needs to have unique values
            label: "PARCELID", //Name field for display. Not pertinent to a grid but may be used elsewhere.
            items: items
        //Create data store and bind to grid.
        store = new ItemFileReadStore({
            data: data
        var grid = registry.byId("grid");
        grid.setStore(store);
        grid.on("rowclick", onRowClickHandler);
        //Zoom back to the initial map extent
        map.centerAndZoom(center, zoom);
    //Zoom to the parcel when the user clicks a row
    function onRowClickHandler(evt) {
        var clickedTaxLotId = evt.grid.getItem(evt.rowIndex).PARCELID;
        var selectedTaxLot = arrayUtils.filter(map.graphics.graphics, function (graphic) {
            return ((graphic.attributes) && graphic.attributes.PARCELID === clickedTaxLotId);
        if (selectedTaxLot.length) {
            map.setExtent(selectedTaxLot[0].geometry.getExtent(), true);
    //end search
}); //end
I'm not sure that what makes this error.
the map before I add this search function was totally fine.
Thank you for your time!
SteveCole
Honored Contributor
You are missing BorderContainer and ContentPane from your list passed to the function. Check that first.
Steve
YungKaiChin
Switch parser and Button function parameters
