Find Locations By Layer Web Map Option
3249
7
05-08-2014 07:44 AM
MaryEllen_Perko
Hi.  This is probably staring right at me, but can anyone explain to me how the map option "Find Locations by Layer" works?  I've set something up in a web map configuration, but I can't figure out what I'm supposed to see in the map.  Or please point me to some documentation that explains it in more detail than the "Set map options for apps" help page.
Thanks.
MikeMinami
Esri Notable Contributor
Currently, only Explorer for ArcGIS supports this
http://doc.arcgis.com/en/explorer/
http://doc.arcgis.com/en/explorer/author-maps/create-a-map.htm#ESRI_SECTION1_4E763B1401D845F5809C99E...
At our next update in July, ArcGIS.com map viewer and the Collector for ArcGIS will support it.
Mike
chris_miller_alaska
Thanks.
Any luck...I'm baffled myself?  I'm beginning to think it only works with layers created in 10.2 but as usual, I haven't been able to find any supporting documentation.
JasperKruggel1
Yes this is also perplexing me.  I was hoping this feature would allow me to search the attributes of a layer, (which I believe it is intended to do), but I also cannot find any such documentation!
MikeMinami
Mike
chris_miller_alaska
Mike
Mike, since the majority of the users utilize desktop browsers to view their web maps, is there a plan to add this feature into the browser based .com Map Viewer? Explorer Online had this ability and it was extremely useful. The filtering functionality in the .com Map Viewer is nice but isn't a replacement for the average (non-GIS) user.  Downloading and customizing a web app isn't an option for many of your users.
--Chris
MikeMinami
Yes.
Mike
chris_miller_alaska
Yes.
Mike
Great! Good to hear. thanks for listening.
--Chris
VeronicaNixon1
I am really excited to finally get to use the new Find Locations by Layer functionality in Collector, but cannot figure out how to enable my web map to be searched. I'm running Server 10.2.2 and ArcGIS Desktop 10.2.2. I published a feature service and toggled Mapping (Data/Map/Query) and Feature Access (Create/Delete/Query/Update) as I was creating it. I created a web map on ArcGIS Online, opened the Edit window, and found the Routing, Measure Tool, Basemap Selector, and Find Locations options at the bottom of the screen. I checked Find Locations, checked By Layer, unchecked By Address, and typed in some Hint Text. I can see from Esri documentation and forum postings that Add Layer is meant to pop up at this point so I can select the layers and the attributes I want to search, however nothing pops up at all. Additionally, when I Save and then open the Edit window again, it has unchecked By Layer and reverted back to By Address.
Any thoughts?
-Veronica
