Label Scale Range Inverted When Displaying Runtime Content
2929
05-05-2014 02:18 PM
JamesRichards1
I'm experimenting with the new Share As... Runtime Content... option in ArcGIS Desktop 10.2.2. I created an offline geodatabase file with a point layer (Cities). The layer has its Scale Range set to "Don't show layer when zoomed out beyond: 1:12,000,000". This looks correct in ArcMap and works fine when publishing the geodatabase file as runtime content, sideloading to the device, and loading the layer into a map using this code:
for (AGSFeatureTable* fTable in [self.geodatabase.featureTables reverseObjectEnumerator]) {     if ([fTable hasGeometry]) {         NSLog(@"adding name: %@", fTable.tableName);         [self.mapView addMapLayer:[[AGSFeatureTableLayer alloc] initWithFeatureTable:fTable]];     } }
I then turned on the "Label features in this layer" option and set the Scale Range of the labels to "Don't show labels when zoomed out beyond: 1:4,000,000". This works correctly in ArcMap, however, when displayed on the device the labels are shown between 4,000,000 and 12,000,000 scale.
Thanks!
James
SuganyaBaskaran1
This seems to be an issue with the SDK. We'll work on fixing it.
Thanks for reporting
Suganya
SuganyaBaskaran1
Suganya
