ArcGIS iOS SDK 10.2.3 License Exception (Esri_runtimecore::Common::License_exception)
1443
05-09-2014 12:25 AM
sivalingam
   I am using ArcGIS iOS SDK v10.2.3 to support offline map and feature editing. I Licensed my app at the Basic level as given in the below link.
https://developers.arcgis.com/ios/guide/license-your-app.htm#ESRI_SECTION1_3D7C830FCBCA48798629E8281...
I downloaded the TPK and Layers local to the app without any issues. When I try to delete or save any features in the AGSFeatureTable I am getting below exception.
libc++abi.dylib: terminating with uncaught exception of type Esri_runtimecore::Common::License_exception: License exception
Here is my code.
AGSFeatureTable* fTable = ....;//Layer id 1 table
AGSGDBFeature *featureEdit = ....;//feature edited under layer id 1
AGSGDBFeature *featureDelete = ....;//feature deleted in layer id 1
[fTable saveFeature:featureEdit error:&error];
[fTable deleteFeature:featureEdit error:&error];
Do I need to get Standard license to enable these features?
DiveshGoyal
Yes, you need a standard license for (as per the doc ) -
Local locators (geocoding)
Local routing
Local geodatabase editing
Local geodatabase sync operations with an upload
DiveshGoyal
Local routing
