Populate new feature attribute table, sequential numbering
1798
6
04-30-2014 03:59 AM
williamcarr
I am attempting to add sequential numbering to newly added graphics, but I'm a little lost on logic. Would this be possible with an i = i + 1 loop? Basically I need to populate an attribute field of a feature layer with a prefix and a number (J1, J2, J3 ect.)
LoriGonzalez
How about this
 var i = 0;        function addGraphic(pt) {            console.log("addingGraphic");            i++;            var symbol = new SimpleMarkerSymbol( SimpleMarkerSymbol.STYLE_CIRCLE,12);             var template = new InfoTemplate("results", "${*}");                           var attr = {};            attr["asdf"] = "J" + i;             var graphic = new Graphic(pt, symbol, attr,template);            map.graphics.add(graphic);                                 //featureLayer.applyEdits([graphic], null, null);            //console.log(" Fire on everything!");        }
LoriGonzalez
That should work. Increment i for every graphic you create using i++; or i=i+1; and then set your attribute to 'J' + i;
williamcarr
              var i= i + 1;
  var attr = {"cycle":"J"+ i};
featureLayer.applyEdits([graphic], null, attr);
I've been playing around with this, but it's not inputting the value. Is that even set up right? It will add the point, but no attributes.
LoriGonzalez
I'm not familiar with the the applyEdit's method of the FeatureLayer but i have used something like this to add attributes to a new graphic.
var attr= {"cycle": "J" + 1};
var graphic= new Graphic(geometry, symbol, attr, infoTemplate);
williamcarr
I got it to add the variable (when I changed it to a stationary number), but it's not adding the sequence.
  var geometry;
       function addGraphic(pt){
            12);
          graphic = new Graphic(pt, symbol,attr);
             var i ;
              var attr = {};
          attr["asdf"] ="J"+ i + 1;
          new esri.geometry.Point(pt, map.spatialReference);
          var newFeature = new esri.Graphic(geometry, null,null);
           graphic.setAttributes(attr);
Any thoughts?
LoriGonzalez
How about this
williamcarr
That got it!!!
Thanks for all your help!
 var i = 0;
        var geometry;
            12);
            i++;
              var attr = {};
          attr["asdf"] = i;
