Programmatically set selected graphic/feature
1952
04-29-2014 06:57 AM
JamesSampica
I add a graphic to the map through code and want to automatically show the infowindow without the user having to click on the graphic. With the code below it just shows an empty infowindow since nothing is selected on the map.
How can I programmatically set the selected feature or graphic?
map.graphics.add(graphic); map.centerAndZoom(graphic.geometry.getCentroid(), 6);  //What I want to do //map.setSelectedGraphic(graphic)  map.infoWindow.show(graphic.geometry.getCentroid());
JonathanUihlein
Something like:
                 map.infoWindow.setFeatures(result);                 map.infoWindow.show(center);
JonathanUihlein
Something like:
JamesSampica
Something like:
Great, thank you.
I had to change it to an array since the setFeatures method accepts an array of graphics or deferreds.
map.infoWindow.setFeatures([graphic]);
