Register SQL Spatial View using Esri Binary
1486
04-28-2014 01:58 PM
mpboyle
Honored Contributor
Does anyone know how to register a SQL spatial view using a feature class that has Esri binary as its shape?
I have tried sdetable -o register and sdetable -o create_view but have been unsuccessful.  This could be because of my own lack of knowledge with the command line.
ArcSDE = 10.1
DBMS = SQL Server 2008 R2
Feature class name = lcbase.dbo.Parcels
Joined table name = gis.dbo.vw_parcels
Trying to create the view in a geodatabase called 'gisstaging'.
Below is the create_view command line prompt I've tried with an error (Error -162, Invalid Database Name)
sdetable -o create_view -T VWTest -t lcbase.dbo.PARCELS,gis.dbo.vw_parcelsweb -c lcbase.dbo.PARCELS.SHAPE,lcbase.dbo.PARCELS.GPNNUM,gis.dbo.vw_parcelsweb.GPN -w"lcbase.dbo.PARCELS.GPNNUM = gis.dbo.vw_parcelsweb.GPN" -i sde:sqlserver:lcgissql -D gisstaging -u **** -p ****
Below is the register command line prompt I've tried after creating the view in SSMS with an error (Error -144, Wrong Column Type, SE_table_get_shape_type failed) --- I'm assuming this is due to the Esri binary shape.
sdelayer -o register -l gisstaging.dbo.ParcelsSearch,Shape -e a -t geometry -i sde:sqlserver:lcgissql -s lcgissql -D gisstaging -u **** -p ****
Any ideas on how I can create a spatial view using an Esri binary feature class...?
Thanks in advance!
VinceAngelo
Esri Esteemed Contributor
You cannot register an existing view on an SDEBINARY layer -- 'sdelayer -o register'
is only used with native (or ST) geometry storage.
The 'sdetable -o create_view' utility is only used to create new views.  It does not
support views that span databases.
It's not formally supported, but the work-around is to create a nominal table (with the same
columns in the same order) in the same database as the layer, then alter the view after it has
been created.
- V
mpboyle
Honored Contributor
Vince,
Thanks for the info!  Once the SDEBINARY feature class was in the same geodatabase as the view, using the sdetable -o create view worked and I was able to see the view as a 'feature' in ArcCatalog.
With feature classes that use GEOMETRY (SQL Server) as their shape, can those views span databases and use the sdetable -o register command to store the view within a different geodatabase than the feature class?
Also - what type of geometry is 'better', SDEBINARY or GEOMETRY for SQL Server?
Thanks again for the knowledge, been trying to figure what the issue was all day!
VinceAngelo
Esri no longer supports the last version that permitted cross-database queries.  There's a
significant performance cost, so their use is not recommended.
The answer is different by use case and even implementation of use case.
- V
