Custom Geocoder Service Not Working with Geocoder Widget
1728
04-17-2014 08:48 AM
JasonLin
I was trying out the Geocoder widget tutorial with our own custom geocoder service but didn't have any luck getting it to work. Not sure if that has something to do with the options within the Geocode object OR the geocoder service configuration needs some tweaking...can someone point me in the right direction for this?
        var geocoder = new Geocoder({           arcgisGeocoder: false,           geocoders: [ {             url: "http://maps.hrsa.gov/arcgis/rest/services/Locators/HDWSMPComposite/GeocodeServer",             name: "Custom",             placeholder: "Find a place",             outFields: "Xmin, Xmax, Ymin, Ymax",             singleLineFieldName: "SingleLine"           }],            map: map         }, dom.byId("search"));
Here's the full jsfiddle
MarlaKostuk
Hey Archenil,
Can you elaborate on what the issue is? I took a look at your code in jsfiddle and it seems like your custom geocoding widget is working like a champ.
-Marla
MarlaKostuk
Hey Archenil,
-Marla
JasonLin
Figured it out myself. I was missing a autocomplete flag. Silly mistake but it's all good now.
          geocoders: [ {
          autoComplete: true,
          map: map
JasonLin
Hey Archenil,
-Marla
Thanks for check it out. It is working like a champ. Good widget, Esri.
MarlaKostuk
Awesome glad to see to see that you were able to fix the issue! Happy coding! :cool:
