Use  Raster Property in Raster Calculater - Problem
1211
7
04-15-2014 08:35 AM
MilenaK
Hello there,
I'm using the model builder to automate several steps.
I'm producing a raster and then I calculate the standard deviation using the tool "Get Raster Properties". After that, I want to extract all cells above the standard deviation. I do this with the "Raster Calculator" and the following expression:
Con( "%Raster%" >= float(%Property%), 1, 0 )
I always get this error: TypeError: float() takes at most 1 argument (2 given).
When I manually calculate the property value it is 2,44945784279457E-05.
My computer language is set to German, I use ArcGIS in English, can that be the problem, that the decimal value is separated by a comma and not by a point?
Would be great if you could support me,
Thanks!
IanMurray
Looking at ArcGIS help, it looks like you can't use float value in your expression in model builder.  Make sure you use a supported variable type.
http://resources.arcgis.com/en/help/main/10.1/index.html#//009z000000z7000000
MilenaK
thank you for your answer!
The float conversion was automatically done when I double clicked the Property.
I tried now different methods, but no one doesn't work.
- If I use round up or instead of Float Int(%Property%) I get this error: TypeError: Int() takes exactly 1 argument (2 given)
- If I just put "%Property%" in it I get an error that the dataset is not supported.
Isn't it possible to calculate the standard deviation of a raster within the Model Builder and the extract all cells above this value?
I would'nt mind in which way I can do it, as long as it works. Can I do anything else so that it will work with the Model Builder?
Or can I convert the property value with another tool to a long or double?
I hope for support,
Thank you!
IanMurray
I'm guessing Property is the field name you are evaluating?  The problem would be the field type then, since it is listed as float.  I would see if you can change the field type to Double.
MilenaK
Yes Property is the calculated standard deviation value which I get from the tool "Get Raster Properties".
There I just can set the type, eg. mean, standard deviation, max, min, ...
The type of the Property Field is set to Variant, I cannot change that.
Any other suggestions?
I just need to extract all values above the standard deviation - is there any other possibilty to get this value?
Thanks for your help anyway!
MilenaK
I found out the problem, when I tried the following expressions:
Con( "%Raster%" >= Float(2,0), 1, 0 ) -> error
Con( "%Raster%" >= Float(2.0), 1, 0 ) -> worked
So it seems that the value in the float statement has to be separated by a dot and not by a comma.
As my language on the computer is set to German, I will try it tomorrow on a computer with the language English, and hopefully the calculated values are separated by a dot.
I will let you know if it worked,
If you have any other suggestions, I would be thankful 🙂
MilenaK
For everyone who is interested. The problem was indeed that the value was separated with a , and not with a .
Changed the language to english - no problems.
IanMurray
Yes, that would be the problem.  I only ever saw the "Property" so I didn't realize you were using commas instead of periods.  When you use commas, that is how it separates parameters, so it thought you were giving 2 inputs instead of one.  Mark this as answered since you got it figured out.
