Arithmetic Overflow error when querying SDE_spatial_references table
971
04-11-2014 10:19 AM
MeleKoneya
When querying our SDE_spatial_references table with SQL Server Management Studio,    I get the following error:
"An error occurred while executing batch. Error message is: Arithmetic Overflow."
We also run a DBCC CHECKDB weekly on our databases and it produces this error:
"Column 'munits' value is out of range for data type "float".  Update column to a legal value."
It looks like the problem is with the munits field in one of our rows and I was able to identify which row this occurs in.     I also took a look at our SDE_Layers table and don't see the SRID that is causing the problem listed.
Has anyone seen this type of error and found a way to resolve it?
Mele
VinceAngelo
Esri Esteemed Contributor
If DBCC is returning errors, you probably want to be talking with Tech Support.
- V
MeleKoneya
- V
Thanks Vince,   I will open a tech support incident regarding this issue.
