QueryTask for dynamicLayer
2702
6
04-09-2014 12:28 PM
tomwang1
I am using ArcGISDynamicMapServiceLayer not FeatureLayer. I am wondering if there a way to query a dynamic layer while user clicks on map? Something likes:
var queryTask =  new QueryTask(dynamicMapServiceUrl + "/dynamicLayer", {
                "source": layerSource
var query = new Query();
query.geometry = clickedMapPoint
JianHuang
Yes, the code snippet that you have should work.
JianHuang
tomwang1
Hi Huang Jian,
Nice to talk you again. I am not sure what I have be missing. I got this error message:
Uncaught TypeError: Object [object Object] has no method 'toJson'
If I change "dynamicMapServiceUrl/dynamicLayer" to "dynamicMapServiceUrl/2" to test my code, it works fine. Also the layerSource has no problem to draw on my map. Please advise!
function createQueryDataSourceLayer(mQuery) {
                  var m_queryDataSource = new esri.layers.QueryDataSource();
                  m_queryDataSource.geometryType = "polygon";
                  m_queryDataSource.oidFields = ["OBJECTID"];
                  m_queryDataSource.query = mQuery;
                  m_queryDataSource.spatialReference = new esri.SpatialReference({ wkid: 102100 });
                  m_queryDataSource.workspaceId = "myworkspace";
                  layerSource = new LayerDataSource();
                  layerSource.dataSource = m_queryDataSource;
                  return layerSource;
JianHuang
What is the layerSource got returned? Please post the json object.
tomwang1
I am not sure how to post json of the layerSource? it is an object. I can see from Chrome console, there are too many object in side.
JianHuang
Or, maybe you can create a simple reproducible case and put it on jsfiddle.net.
tomwang1
Thanks Huang Jian,
It was my mistake.  QueryTask for dynamicLayer works fine with no problem!
