List Widget Code
3324
04-04-2014 08:28 AM
PatrickWhysong
I am investigating building a new widget using the ArcGIS Runtime WPF SDK for the Operations Dashboard.  Does the code exist for the List Widget for download?  I would really like to build something similar to the List widget plus more custom functionality within the list result.  Or is there a way to extend the list widget?
Pat
TifPun
Hi Pat,
The source code of Operations Dashboard is not open and the built-in functions are not extensible, so a custom widget will be the way to go. However, there is a Dashboard sample implementing a list widget with feature actions that comes with the WPF SDK. The location of the sample's source code is typically at: C:\Program Files (x86)\ArcGIS SDKs\WPF10.2.3\sdk\samples\sampleapplication\Operations Dashboard Samples\WidgetWithFeatureActionsCS. You can take it as a reference when you develop your custom list widget.
Thanks and any questions please let me know,
Tif
PatrickWhysong
Hi Tif
Thank you for confirming about the List Widget.  In the mean time I was able to create a custom widget to consume the result of the List Widget.  However I am unable to actually execute a query against the List Widget Datasource.  Would you happen to know if there is an actual example of consuming the List Widget result as a datasource from within a custom widget?
Also, I am very new to the ArcGIS Runtime WPF SDK, so I apologize in advance if this is a newbie question.
Pat
Hi Pat,
Tif
