Using token managed security, trying to bypass login with hardcoded credentials for intranet users. For some reason, even though the token comes back clean and the credential object is created, the login box still pops up? Shouldn't the IdentityManager know a token has been created and use it? I thought that is what the esri.id.initialize did function initPredefinedSecurity() {
//alert('in initPredefinedSecurity');
serverInfo = new ServerInfo();
serverInfo.server = 'https://www.mymanatee.org/arcgis03';
serverInfo.tokenServiceUrl = 'https://www.mymanatee.org/arcgis03/tokens/generateToken';
serverInfo.shortLivedTokenValidity = 720;
esri.id.registerServers([serverInfo]);
var def = esri.id.generateToken(serverInfo, {"username": "util", "password": "util"});
def.addCallback(lang.hitch(this, function (tokenInfo) {
//var idBase = new IdentityManagerBase();
//get token creation time in epoch
var creationTime = (new Date).getTime();
//calculate the token expiration based on short lived token validity
var expirationTime = creationTime + (serverInfo.shortLivedTokenValidity * 60000);
//create array of secured services
var idObject ={};
idObject.serverInfos= [serverInfo];
var credentials={};
credentials.userId = "util";
credentials.server = "https://www.mymanatee.org/arcgis03";
credentials.token = tokenInfo.token;
credentials.expires = expirationTime;
credentials.ssl = true;
credentials.creationTime = creationTime;
idObject.credentials = [credentials];
console.dir(idObject);
//credential object is correct
esri.id.initialize(idObject);
//sign in dialog pops up
