Extract data AMD widget
2653
5
03-21-2014 10:17 AM
AlexGole1
I was wondering if anybody had samples/examples on how to implement this widget. I am already using this script which works well but I would like to customize it so the users can extract data by a specific extent (chosen county, parcel unit ect...)
Thank you,
Alex
JakeSkinner
Esri Esteemed Contributor
Hi Alex,
Take a look at this thread.  There is an example where you can select a graphic and export it to a shapefile through the infoWindow.
WhereMatters
Hi Jake,
I am not able to click on the link you mention in your reply to Alex. I tried viewing this in the latest version of Chrome as well as IE 11 and the links are just not clickable although they look like links, i mean they are blue (or greyish blue, cant really tell)  in color. Can you please provide the full link?
JakeSkinner
Hi Anand,
Looks like the migration to GeoNET broke some hyperlinks.  Below is the code:
<!DOCTYPE html>
<html>
  <head>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <title></title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css">
    <style>
      html, body, #mapDiv {
        padding:0;
        margin:0;
        height:100%;
      #loading {
        display: none;
        vertical-align: middle;
    </style>
    <script src="http://js.arcgis.com/3.8/"></script>
    <script>
      var map, featureLayer, gp;
      require([
        "esri/map", "esri/config", "esri/layers/FeatureLayer", "esri/InfoTemplate", "esri/tasks/FeatureSet", "esri/geometry/Extent",
        "esri/layers/GraphicsLayer", "esri/tasks/Geoprocessor",
        "dijit/form/Button", "dojo/parser", "dijit/registry", "dojo/dom", "dojo/on", "dojo/dom-style", "dojo/domReady!"
      ], function(
        Map, esriConfig, FeatureLayer, InfoTemplate, FeatureSet, Extent,
        GraphicsLayer, Geoprocessor,
        Button, parser, registry, dom, on, domStyle
        parser.parse();
        esriConfig.defaults.io.proxyUrl = "proxy.ashx";
        var loading = dom.byId("loading");
        map = new Map("mapDiv", {
          basemap: "streets",
          center: [-117.1625, 32.7150],
          zoom: 13
        var infoTemplate = new InfoTemplate("Details", "<tr>OBJECTID: <td>${objectid}</tr></td><br><br><button id='button' dojoType='dijit.form.Button'>Export</button>");
        featureLayer = new FeatureLayer("http://sampleserver4.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/Incident_Data_Extraction...",{
            mode: FeatureLayer.MODE_ONDEMAND,
            infoTemplate: infoTemplate,
            outFields: ["*"]
        map.addLayer(featureLayer);
        gp = new Geoprocessor("http://sampleserver4.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/Incident_Data_Extraction...");
                gp.setOutSpatialReference({
                    wkid : 102100
        on(map.infoWindow, "show", function(){
          on(dom.byId("button"), "click", extractData);
        function pointToExtent(map, pointX, pointY, tolerance){
            var xmin = pointX - tolerance;
            var ymin = pointY - tolerance;
            var xmax = pointX + tolerance;
            var ymax = pointY + tolerance;
            return new Extent(xmin, ymin, xmax, ymax, map.spatialReference)
        function extractData() {
            var extent = pointToExtent(map, map.graphics.graphics[0].geometry.x, map.graphics.graphics[0].geometry.y, 10);
            map.graphics.add(extent);
            var featureSet = new FeatureSet();
            var features = [];
            features.push(map.graphics.graphics[0]);
            featureSet.features = features;
            var params = {
                "Layers_to_Clip" : ["Incident Areas"],
                "Area_of_Interest" : featureSet,
                "Feature_Format" : "Shapefile - SHP - .shp"
            domStyle.set(loading, "display", "inline-block");
            gp.submitJob(params, completeCallback, statusCallback, function(error) {
                alert(error);
                domStyle.set(loading, "display", "none");
        function completeCallback(jobInfo){
          if ( jobInfo.jobStatus !== "esriJobFailed" ) {
            gp.getResultData(jobInfo.jobId, "Output_Zip_File", downloadFile);
        function statusCallback(jobInfo) {
          var status = jobInfo.jobStatus;
          if ( status === "esriJobFailed" ) {
            alert(status);
            domStyle.set("loading", "display", "none");
          else if (status === "esriJobSucceeded"){
        function downloadFile(outputFile){
          var theurl = outputFile.value.url;
          window.location = theurl;
    </script>
  </head>
  <body>
    <div id="mapDiv">
        <img id="loading" src="images/loading.gif">
    </div>
  </body>
</html>
WhereMatters
Thanks Jake this helps.
Can you please take a look at a related question I posted and let me know if you have any ideas/suggestions?
https://community.esri.com/message/397744?sr=search&searchId=f7f71b54-ca93-49f3-893b-8a8a41937623&se...
AlexGole1
Hi Alex,
That is a great script I will add this to my web map app. I would also need to be able to export data by a simple definition query. For instance, I have a Feature layer containing the wildfires areas(polys) that has one field called county. I would love users to be able to extract data by a simple field SQl query. For instance:  if "county" = "Alameda" then export to shp. Any ideas on how to proceed for such a task?
Thank you,
Alex
