I am trying to add custom labels to graphics points. Each graphic having its own unique label. Thanks for the help. -------------------------------------------------------------- <!DOCTYPE HTML> <html> <head> <meta charset="utf-8"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Basemap Toggle</title> <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.8/js/esri/css/esri.css"> <style> html, body, #map { padding:0; margin:0; height:100%; } </style> <script src="//js.arcgis.com/3.8/"></script> <script> var map; require([ "esri/map", "dojo/domReady!" ], function( Map ) {
var map = new Map("map", { center: [-81.057, 34.005], zoom: 7, basemap: "national-geographic", fadeOnZoom: true, slider: false, nav: false, wrapAround180: true, }); //------Add Point Graphic------------------------------ require(["dojo/_base/Color","esri/lang","esri/graphic","esri/layers/GraphicsLayer","esri/renderers/SimpleRenderer", "esri/geometry/Point","esri/tasks/FeatureSet","esri/symbols/SimpleMarkerSymbol","esri/symbols/SimpleLineSymbol", "dojo/domReady!" ], function( Color, esriLang, Graphic, GraphicsLayer, SimpleRenderer, Point, FeatureSet, SimpleMarkerSymbol, SimpleLineSymbol){ var facilityPointSymbol = new SimpleMarkerSymbol( SimpleMarkerSymbol.STYLE_CIRCLE, 15, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([60,50,255]), 2 ),new Color([169,250,20,0.6]));
var facilitiesGraphicsLayer = new GraphicsLayer(); var facilityRenderer = new SimpleRenderer(facilityPointSymbol); facilitiesGraphicsLayer.setRenderer(facilityRenderer);
