Create Thiessen Polygons ERROR 999998 Unexpected Error
2851
03-19-2014 05:00 AM
OlegMueller
Hi all,
when I try to create a thiessen polygon from approx. 1000000 feature points in ArcGIS Desktop, it fails after a few seconds with the error message above. Are 1 million points too much?
thanks a lot
DuncanHornby
MVP Notable Contributor
Oleg,
1 million points is a large dataset but ArcMap should be able to handle that. In my experience large datasets often have errors in them. Have you run your point dataset through the check geometry tool, may be you have null geometries? Do all fields have values, e.g. no null value?
Duncan
OlegMueller
Oleg,
Duncan
Thank you Duncan. I have used the check geometry tool, everything was ok. But then I used the delete identical tool. After this tool, the thiessen polygon calculation worked.
