Esri bootstrap-map-js and Invalid argument error on IE 7/8
1782
03-16-2014 08:58 PM
LenielMaccaferri
I'm using this awesome project called bootstrap-map-js.
A simple framework for building responsive mapping apps with ArcGIS and Bootstrap.
Since Esri ArcGIS JavaScript API states that they support IE7+ I thought the amazing bootstrap-map-js project would also be compatible with IE 7. Maybe it is and the problem is in my code...
I'm getting an Invalid Argument error with no further info on IE 11 Developer Tools console window when simulating the page on IE 7/8 document modes. IE 9 onwards works great. All other browsers work great too! 🙂 Only finicky IE refuses to work as always...
Looks like dojo.require is barking somewhere. See this related question: Dojo nested requires on IE7 and IE8 causes Invalid Argument Exception
If I remove the reference to bootstrapmap.js and the var map = ... declaration, then the code works and I see hey Leniel! otherwise the code breaks and I see the Invalid argument. The code breaks in the call to BootstrapMap.create.
Can anyone shed some light on what's going on with finicky IE? Is there anything I can do to see more from the error? As you see in the image, there's no message, description, etc. 😞
Here's the minimum code I had to assemble to get to what was causing the error:
<!-- ArcGIS JavaScript API v3.8 -->
<script type="text/javascript" src="http://localhost/arcgis_js_api/library/3.8/3.8/init.js"></script>
<script type="text/javascript">
function init()
    require([
        "esri/map",
        "/myproject/Scripts/bootstrapmap.js",
        "esri/layers/FeatureLayer"
    ], function(
        Map,
        BootstrapMap,
        FeatureLayer
        // Get a reference to the ArcGIS Map class
        var map = BootstrapMap.create("mapDiv", {
            basemap: "oceans",
            center: [-117.789, 33.543],
            zoom: 12
        alert('hey Leniel!');
dojo.addOnLoad(init);
</script>
AllanLaframboise
