Loop in python with Zonal Statistics
4168
03-13-2014 05:58 AM
KrzysztofSterenczak
I have following problem. I have a layer with thousands of objects - crowns. I have CHM (nDSM) with "height" values. I would like to calculate "All" height statistics for crowns based on CHM, crown after a crown - because to do so directly in Spatial Analyst is impossible (to many objects in layer). I tried to write a Python script (one of my first ones) but it simply does not work:
import arcpy
import os
from arcpy import env
from arcpy.sa import *
# Set environment settings
env.workspace = "F:\\_IBL\\Projekty\\GDLP_Sudety_Beskidy\\Analizy\\ALS2007vs2012\\analiza_probna\\baza.gdb"
outWorkspace = "F:\\_IBL\\Projekty\\GDLP_Sudety_Beskidy\\Analizy\\ALS2007vs2012\\analiza_probna\\baza.gdb"
featureClass = "korony_proba"  # crowns
raster2007 = "T2007_proba" #CHM (nDSM) ??? 32 bit, flout
rows = arcpy.SearchCursor(featureClass)
row = rows.next()
for row in rows:
inZoneData = "featureClass"
zoneField = "ID_OK"
inValueRaster = "raster2007"
outTable = "stat_2007"
outZSaT = ZonalStatisticsAsTable(inZoneData, zoneField, inValueRaster, outTable, "NODATA", "ALL")
I have following error on the beginning:
Runtime error  Traceback (most recent call last):
File "<string>", line 11, in <module>
File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\sa\Functions.py", line 6195, in ZonalStatisticsAsTable     statistics_type)
File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\sa\Utils.py", line 47, in swapper     result = wrapper(*args, **kwargs)
File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\sa\Functions.py", line 6187, in Wrapper     statistics_type)
File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\geoprocessing\_base.py", line 498, in <lambda>     return lambda *args: val(*gp_fixargs(args, True)) ExecuteError: ERROR 000865: Input raster or feature zone data: featureClass does not exist. ERROR 001000: Zone field: Field ID_OK does not exist ERROR 000865: Input value raster: raster2007 does not exist.
Can you help me please.
Kris
ClintDow
Hello, a couple things that might help:
You are mixing up two methods of using the cursor in this section
rows = arcpy.SearchCursor(featureClass) row = rows.next() for row in rows:
You do not need to assign row = rows.next() unless you are using a while loop, in a for loop using the cursor as a sequence to loop through is enough.
In the line inZoneData = "featureClass" you are assigning the string 'featureClass' rather than assigning the value from the featureClass variable. Therefore the script is looking for a feature class named 'featureClass' in your workspace rather than a feature class named 'korony_proba' - this is the cause of ERROR 000865: Input raster or feature zone data: featureClass does not exist.
Since that doesn't exist, there is no ID_OK field to find, hence the  ERROR 001000: Zone field: Field ID_OK does not exist
ERROR 000865: Input value raster: same issue as with the feature class, its looking for a raster named 'raster2007' rather than assigning 'T2007_proba' to that variable.
ClintDow
KrzysztofSterenczak
Dear Clinton,
Thank you very much for tis tips. Now I solved a problem.
Final code:
import arcpy
import os
for row in rows:
# Set local variables
inZoneData = "rosnace"
zoneField = "ID_OK"
inValueRaster = "T2007"
outTable = "stat_2007_test1"
# Execute ZonalStatisticsAsTable
As a result I have table with all statistics and with error:
ERROR 000872: Output table: Output F:\_IBL\Projekty\GDLP_Sudety_Beskidy\Analizy\ALS2007vs2012\analiza_probna\baza.gdb\stat_2007_test1 exists. It cannot be overwritten since overwrite is off.
When I added:
Error did not show off but table was empty and procedure did not stoped.
Nevertheless I reached my aim so thank you very much ones again.
Kris
XanderBakker
Esri Esteemed Contributor
Hi Krzysztof,
Clint already indicated some flaws in the code. Another one is the fact that you do a loop over your features, but nothing is actually done with the feature itself. What you should do in the loop is create a feature layer of the single feature and use that feature layer in the zonal statistics tool.
See below an example of how this could be done:
import arcpy
import os
outWorkspace = r"C:\Project\_Forums\_json\fgdb\crawlAHN2.gdb"
arcpy.env.workspace = outWorkspace
# reference to the data
fc = os.path.join(outWorkspace, "crowns")
raster = os.path.join(outWorkspace, "AHN2r")
zoneField = "ID_OK"
# temporal output ZS table will be (over)written to in memory workspace
outTable = os.path.join("IN_MEMORY", "stat_zs")
# name of feature layer (lives in memory)
flyr_name = 'a_crown'
# get list of zones (this is used for the loop)
lst_zones = [row[0] for row in arcpy.da.SearchCursor(fc, (zoneField))]
# create an empty dictionary to store the statistics results
dct_stats = {}
# create a dictionary that holds the statistics type and the corresponding output field names
dct_stat_fld = {'MEAN': 'cr_mean',
                'MAX':  'cr_max',
                'MIN': 'cr_min',
                'STD': 'cr_std'}
# list of fields in ZS table that hold the statistics I'm interested in ['MEAN','MIN','MAX','STD']
lst_flds = [fld for fld in dct_stat_fld.iterkeys()]
# get sa license
# now loop through zones and make a featurelayer with only that zone feature (crown)
cnt = 0
for zone in lst_zones:
    cnt += 1
    # give some feedback on progress
    if cnt % 10 == 0:
        print "Processing crown: {0} ({1})".format(cnt, zone)
    # create the where clause for that crown
    where = "{0} = '{1}'".format(arcpy.AddFieldDelimiters(fc, zoneField), zone)
    # make the featurelayer of current crown (zone)
    arcpy.MakeFeatureLayer_management(fc, flyr_name, where)
    # calculate the zonal statistics for that crown
    arcpy.sa.ZonalStatisticsAsTable(flyr_name, zoneField, raster, outTable, "NODATA", "ALL")
    # read the ZS table and write to dictionary
    with arcpy.da.SearchCursor(outTable, lst_flds) as curs:
        for row in curs:
            i = 0
            for fld in lst_flds:
                key = (zone, fld) # looks like ('crown ID', 'statistics type like MIN')
                dct_stats[key] = row
                i += 1
# return sa license
arcpy.CheckInExtension("Spatial")
# create update field collection (field  for the update cursor)
flds = [zoneField]
flds.extend([dct_stat_fld[fld] for fld in lst_flds])
# do an update cursor to write the results from dictionary to crown featureclass
with arcpy.da.UpdateCursor(fc, flds) as curs:
    for row in curs:
        zone = row[0]
        i = 1
            key = (zone, fld)
            if key in dct_stats:
                row = dct_stats[key]
            i += 1
        curs.updateRow(row)
I hope this is useful for you.
Kind regards,
Xander
