Error in adding RapidEye Rasters to a Mosaic Dataset
2282
5
03-12-2014 09:44 AM
VitorFranca
Our company has acquired a huge collection of RapidEye imagery. To maximize it's use inside the organization, we intend to create image services based on mosaic datasets.
So, I've been attempting to create raster mosaics in a file geodatabase using ArcGIS for Desktop 10.2.1 (Advanced) in a Windows 7 64 bits workstation. After creating the geodatabase and the mosaic dataset using "RAPIDEYE_5BANDS" product definition and "16_BITS_UNSIGNED" as pixel type, I've been getting successive error messages in attempting to add rasters. Using the "Add Rasters to Mosaic Dataset" tool, filled with defaults "RapidEye" Raster Type and "*metadata.XML" as Input Data Filter, I get the following error messages:
Executing: AddRastersToMosaicDataset E:\Acervo\RapidEye.gdb\Acervo_2012 RapidEye \\??????????\?\??????\2011\????????\???????\FUSO_18S UPDATE_CELL_SIZES UPDATE_BOUNDARY NO_OVERVIEWS # 0 1500 # *metadata.xml SUBFOLDERS EXCLUDE_DUPLICATES NO_PYRAMIDS NO_STATISTICS NO_THUMBNAILS # NO_FORCE_SPATIAL_REFERENCE
Start Time: Wed Mar 12 14:05:57 2014
2014-03-12T14:05:57.827: Loading raster datasets
2014-03-12T14:06:05.451: Completed crawling 163 data source items. Added 163 mosaic dataset items.
2014-03-12T14:06:05.452: Synchronizing crawled data source items
2014-03-12T14:06:05.477: Synchronizing items associated with raster type instance 'RapidEye' [ID: 1].
2014-03-12T14:06:05.481: Preparing distribution of mosaic dataset operation across 8 parallel instances.
2014-03-12T14:06:10.680: Error: 8004206c: Failures reported while processing specified command item. [1]
2014-03-12T14:06:10.681: Error: 80042019: Chained Error ID: oX80042019
2014-03-12T14:06:10.681: Error: 80042019: Could not build mosaic dataset item. [ID: 1, URI: '\\????????????\?\??????????\?????\???????????????????\?????????\1834427_2011-08-24T161311_RE1_3A-NAC_11049742_149122\1834427_2011-08-24T161311_RE1_3A-NAC_11049742_149122_metadata.xml']
2014-03-12T14:06:10.682: Error: 8004203f: Could not open source as a raster dataset. [\\????????????\?\??????????\?????\???????????????????\?????????\1834427_2011-08-24T161311_RE1_3A-NAC_11049742_149122\2011-08-24T161311_RE1_3A-NAC_11049742_149122.tif]
2014-03-12T14:06:10.682: Error: 80040213: Failed to open raster dataset
2014-03-12T14:06:10.683: Error: 8004206c: Failures reported while processing specified command item. [2]
2014-03-12T14:06:10.685: Error: 80040213: Failed to open raster dataset......
2014-03-12T14:06:11.034: Error: 8004205e: 163 mosaic dataset items could not be built.
2014-03-12T14:06:11.035: Removing broken mosaic dataset items.
2014-03-12T14:06:11.048: Removing unreferenced raster type and overview instances
2014-03-12T14:06:11.050: Removed 163 mosaic dataset items and 1 unreferenced raster type instances.
2014-03-12T14:06:11.103: Completed synchronization: 163 items selected, 0 items synchronized.
2014-03-12T14:06:11.104: Processing duplicate mosaic dataset items
2014-03-12T14:06:11.105: Removed 0 duplicate mosaic dataset items.
Succeeded at Wed Mar 12 14:06:16 2014 (Elapsed Time: 18,56 seconds)
I can add rasters using "Raster Dataset" as Input Data and "*[0-9].TIF" wildcard as Input Data Filter, but this does not fill in parameters in the Footprint attribute table like 'Sun Azimuth' or 'OffNadir' contained in the *_metadata file for each scene. I suppouse ArcGIS uses these parameters for improving mosaic quality and display.
Any advice?
larryzhang1
New Contributor III
Vitor,
It looks that your RE products are not supported in ArcGIS (MD)�?� not sure if those are standard RE products (1B or 3A).
In fact, we also had same issue with RapidEye products, which is exactly similar to Astruim standard products (SPOT 5, Pleiades PAN). We already reported this Astruim (SPOT 5, Pleiades, and SPOT 6) issue as remedy to ESRI and urgently wait for their reply. For details, please refer to the discussion thread at http://forums.arcgis.com/threads/81139-to-expedite-the-development-supporting-RPCs-of-Pleiades-senso...
So, advisable to report it as the remedy and seek ESRI for investigation�?�
To me, the issues with Pleiades and SPOT 6 are bugs in ArcGIS.
However, with RapidEye products (1B, 3A) and SPOT 5 products (1A, 2A), not sure what leads to this happening during loading into MD? (I.e., our operational data from vendors are Not 'standard bundle' or bugs in MD?)...
VitorFranca
larry,
We have solved the issue. Our RapidEye imagery metadata files (*_metadata.xml) , for some reason, had incorrect strings for fileName fields under "resultOf" block ("BrowseInformation", "ProductInformation" and "MaskInfomation"). We have created new metadata files with correct references for quicklooks, product and mask files. After that, we were able to create Mosaic Datasets using "RapidEye" raster type.
Thank you,
Vitor
larryzhang1
New Contributor III
Thx,
The Q is:
Are your data not from the vendor directly? In other word, if you are going to modify the metadata one by one, it would be an operational issue. Isn�??t it? How is that happening?
For our case, RepidEye �??RPC�?? model can be correctly read by other remote sensing package like Erdas or PCI, but not MD.
VitorFranca
Our data was acquired under a special "government" license type. We have not received the data directly form vendor, but from a resseler. We'll notify them about the issue. I am using Safe FME Workbench to automate generation of new metadata files with correct file names.
larryzhang1
New Contributor III
Yes, clearer now.
For our cases, ESRI 10.2.2 will start support it. Pls read the attachment
