Bookmarks and calling code from different modules
2339
5
03-11-2014 03:12 AM
deleted-user-yA_w_FC9FKe5
I have been doing some developement in Silverlight and Flex for awhile now.  However, Javascript and HTML5 really seem the way to go now that my company has invested in a bunch of iPads.  So I am trying to learn as I go.  I have a couple of questions.
1.) I would rather not have all of my code in one place.  I will have a lot of bookmarks.  How can I call these from another file?
2.) Can I just set the spatialreference once for my bookmarks instead of every single time?
        // --->Bookmarks
        var bookmarks_list = [{
          "extent": {"spatialReference": {"wkid": 102100},"xmin":-13587617,"ymin":4564540,"xmax":-13587178,"ymax":4564976},
          "name": "BroadWay Plaza!"},
    {"extent": {"spatialReference": {"wkid":102100},"xmin":-13837359,"ymin":4507794,"xmax":-13501037,"ymax":4866253},
          "name": "Bay Area North District"
  //------>End of bookmarks
KenBuja
MVP Esteemed Contributor
Here's one way to do it. You can use a module that contains the booksmarks. Here is a tutorial about creating modules. Create a separate Javascript file called "Bookmarks.js" in a directory called modules. That files looks like this
define([], function () {     return {         list: [{             "extent": {                 "spatialReference": {                     "wkid": 102100                 },                 "xmin": -14201669,                 "ymin": 4642975,                 "xmax": -13021482,                 "ymax": 5278931             },             "name": "Northern California"         }, {             "extent": {                 "spatialReference": {                     "wkid": 102100                 },                 "xmin": -8669334,                 "ymin": 4982379,                 "xmax": -8664724,                 "ymax": 4984864             },             "name": "Central Pennsylvania"         },         {             "extent": { "spatialReference": { "wkid": 102100 }, "xmin": -13587617, "ymin": 4564540, "xmax": -13587178, "ymax": 4564976 },             "name": "BroadWay Plaza!"         }, ]     }; });
You can use that module in the code like this (adapted from the Bookmark Sample😞
<!doctype html> <html> <head>     <meta charset="utf-8">     <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">     <title>Bookmark Widget(Read-only Bookmarks)</title>     <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dijit/themes/nihilo/nihilo.css">     <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css">     <style>         html, body {             height: 100%;             width: 100%;             margin: 0;             padding: 0;         }          body {             background-color: #fff;             overflow: hidden;             font-family: sans-serif;         }          #header {             padding-top: 4px;             padding-left: 15px;             background-color: #444;             color: #fff;             font-size: 16pt;             text-align: left;             font-weight: bold;             height: 55px;         }          #subheader {             font-size: small;             color: #cfcfcf;             text-align: left;         }          #bookmarks-wrapper {             position: absolute;             z-index: 40;             top: 15px;             right: 30px;             background: transparent;             font-size: 12pt;             color: #444;         }          .ds {             background: #000;             overflow: hidden;             position: absolute;             z-index: 2;         }          #ds-h div {             width: 100%;         }          #ds-l div {             height: 100%;         }          #ds .o1 {             filter: alpha(opacity=10);             opacity: .1;         }          #ds .o2 {             filter: alpha(opacity=8);             opacity: .08;         }          #ds .o3 {             filter: alpha(opacity=6);             opacity: .06;         }          #ds .o4 {             filter: alpha(opacity=4);             opacity: .04;         }          #ds .o5 {             filter: alpha(opacity=2);             opacity: .02;         }          #ds .h1 {             height: 1px;         }          #ds .h2 {             height: 2px;         }          #ds .h3 {             height: 3px;         }          #ds .h4 {             height: 4px;         }          #ds .h5 {             height: 5px;         }     </style>     <script>         var dojoConfig = {             parseOnLoad: true,             packages: [                 {                     name: "modules",                     location: location.pathname.replace(/\/[^/]+$/, "") + "/modules"                 }              ]         };     </script>     <script src="http://js.arcgis.com/3.8/"></script>     <script>          var map, bookmarks;          require(["esri/map", "esri/dijit/Bookmarks", "modules/Bookmarks", "dojo/dom",                  "dojo/domReady!"],             function (map, Bookmarks, modBookmarks, dom) {                 map = new map("map", {                     basemap: "topo",                     center: [-100, 40],                     zoom: 4                 });                  // Create the bookmark widget                 bookmarks = new Bookmarks({                     map: map,                     bookmarks: modBookmarks.list                 }, dom.byId('bookmarks'));             });     </script> </head> <body class="nihilo">     <div id="mainWindow"          data-dojo-type="dijit/layout/BorderContainer"          data-dojo-props="design:'headline',gutters:false"          style="width: 100%; height: 100%; margin: 0;">         <div id="header"              data-dojo-type="dijit/layout/ContentPane"              data-dojo-props="region:'top'">             Bookmark Widget Sample             <div id="subheader">Read-only bookmarks</div>              <!-- Bookmarks widget inside a Drop Down Button -->             <div id="bookmarks-wrapper">                 <div data-dojo-type="dijit/form/DropDownButton">                     <span>Bookmarks</span>                     <div data-dojo-type="dijit/TooltipDialog">                         <div id="bookmarks"></div>                     </div>                 </div>             </div>          </div>         <div id="map" class="shadow"              data-dojo-type="dijit/layout/ContentPane"              data-dojo-props="region:'center'">              <div id="ds">                 <!-- drop shadow divs -->                 <div id="ds-h">                     <div class="ds h1 o1"></div>                     <div class="ds h2 o2"></div>                     <div class="ds h3 o3"></div>                     <div class="ds h4 o4"></div>                     <div class="ds h5 o5"></div>                 </div>             </div> <!-- end drop shadow divs -->          </div>     </div> </body> </html>
I have a feeling someone knows the answer to this question but they are not sharing.
KenBuja
Thanks that was very usefull
KenBuja
To do this without having the spatial reference in each bookmark, you have to add some extra code to add it.
        require(["esri/map", "esri/dijit/Bookmarks", "modules/Bookmarks", "dojo/dom", "dojo/_base/array", "dojo/_base/lang",
                 "dojo/domReady!"],
            function (map, Bookmarks, modBookmarks, dom, array, lang) {
                    basemap: "topo",
                    center: [-100, 40],
                    zoom: 4
                var bookmark_list = [];
                array.forEach(modBookmarks.list, function (item) {
                    lang.mixin(item.extent, { "spatialReference": { "wkid": 102100 } });
                    bookmark_list.push(item);
                    map: map,
                    bookmarks: bookmark_list
KenBuja
Glad to help. Don't forget to mark the post as answered to help those who are searching on this question.
