Bookmarks
836
03-07-2014 06:20 AM
deleted-user-yA_w_FC9FKe5
I saw a couple of bookmark examples but my problem lies in that I don't want my bookmarks all listed in my main html file.  I have over 700 bookmarks.  Is it possible to use the bookmarks widget or something else and call the bookmarks from another file?
SteveCole
Honored Contributor
One option might be to store your bookmark information in a standalone table that's tucked inside one of your published services and then just use a queryTask on the table to retrieve the needed information (e.g. "NAME='Times Square'").
Steve
DavideLimosani
if you want to put your bookmarks in another file you can do something like this:
html file:
<!doctype html>
<html>
  <head>
    <meta charset="utf-8">
    <title>Bookmark Widget (Editable)</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dijit/themes/nihilo/nihilo.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css">
    <style>
      html, body {
        height: 100%; width: 100%;
        margin: 0; padding: 0;
      body{
        background-color: #fff; overflow:hidden;
        font-family: sans-serif;
      #header {
        padding-top: 4px;
        padding-right: 15px;
        background-color:#444;
        color:#fff;
        font-size:16pt; text-align:right;font-weight:bold;
        height:55px;
      #subheader {
        font-size:small;
        color: #cfcfcf;
        text-align:right;
      #leftPane{
        margin: 0;
        padding: 5px;
        width: 250px;
        color: #3C1700;
      .ds { background: #000; overflow: hidden; position: absolute; z-index: 2; }
      #ds-h div { width: 100%; }
      #ds-l div { height: 100%; }
      #ds .o1 { filter: alpha(opacity=10); opacity: .1; }
      #ds .o2 { filter: alpha(opacity=8); opacity: .08; }
      #ds .o3 { filter: alpha(opacity=6); opacity: .06; }
      #ds .o4 { filter: alpha(opacity=4); opacity: .04; }
      #ds .o5 { filter: alpha(opacity=2); opacity: .02; }
      #ds .h1 { height: 1px; }
      #ds .h2 { height: 2px; }
      #ds .h3 { height: 3px; }
      #ds .h4 { height: 4px; }
      #ds .h5 { height: 5px; }
      #ds .v1 { width: 1px; }
      #ds .v2 { width: 2px; }
      #ds .v3 { width: 3px; }
      #ds .v4 { width: 4px; }
      #ds .v5 { width: 5px; }
    </style>
    <script>        var dojoConfig = { parseOnLoad: true };</script>
    <script src="http://js.arcgis.com/3.8/"></script>
        <script type="text/javascript" src="bookmarks.js">
    </script>
    <script>
        dojo.require("dijit.layout.BorderContainer");
        dojo.require("dijit.layout.ContentPane");
        dojo.require("esri.map");
        dojo.require("esri.dijit.Bookmarks");
        var map;
        function init() {
            map = new esri.Map("map", {
                basemap: "topo",
                center: [-100, 40],
                zoom: 4
            // Create the bookmark widget
            // specify "editable" as true to enable editing
            var bookmarkWidget = new esri.dijit.Bookmarks({
                map: map,
                bookmarks: [],
                editable: true
            }, dojo.byId('bookmark'));
            dojo.forEach(bookmarks, function (bookmark, i) {
                console.log("bookmark", bookmark);
                bookmarkWidget.addBookmark(bookmark);
        //show map on load
        dojo.ready(init);
    </script>
  </head>
  <body class="nihilo">
    <div id="mainWindow"
         data-dojo-type="dijit.layout.BorderContainer"
         data-dojo-props="design:'headline',gutters:false"
         style="width: 100%; height: 100%; margin: 0;">
      <div id="header"
           data-dojo-type="dijit.layout.ContentPane"
           data-dojo-props="region:'top'">
        Bookmark Widget Sample
        <div id="subheader">Create, update and delete bookmarks</div>
      </div>
      <div id="leftPane"
           data-dojo-props="region:'left'">
        <div id="bookmark"></div>
      </div>
      <div id="map" class="shadow"
           data-dojo-props="region:'center'">
        <div id="ds"> <!-- drop shadow divs -->
          <div id="ds-h">
            <div class="ds h1 o1"></div>
            <div class="ds h2 o2"></div>
            <div class="ds h3 o3"></div>
            <div class="ds h4 o4"></div>
            <div class="ds h5 o5"></div>
          </div>
          <div id="ds-l">
            <div class="ds v1 o1"></div>
            <div class="ds v2 o2"></div>
            <div class="ds v3 o3"></div>
            <div class="ds v4 o4"></div>
            <div class="ds v5 o5"></div>
          </div>
        </div> <!-- end drop shadow divs -->
      </div>
    </div>
  </body>
</html>
bookmarks.js file:
// Add bookmarks to the widget
bookmarks=[];
var bookmarkCA = {
    "extent": {
        "spatialReference": {
            "wkid": 102100
        "xmin": -14201669,
        "ymin": 4642975,
        "xmax": -13021482,
        "ymax": 5278931
    "name": "Northern California"
var bookmarkPA = {
    "extent": {
            "wkid": 102100
        "xmin": -8669334,
        "ymin": 4982379,
        "xmax": -8664724,
        "ymax": 4984864
    "name": "Central Pennsylvania"
bookmarks.push(bookmarkCA);
bookmarks.push(bookmarkPA);
Davide
