Tkinter, ArcPy and Threading
3425
02-25-2014 10:45 AM
TangoPapa
Hey All,
Just wanted to get a solid answer from someone.  My question is very similar to:
http://forums.arcgis.com/threads/63390-Bug-with-arcpy-in-a-thread (2012)
I'm trying to intermittently inject data into an SDE in Python (via a Tkinter interface).  I would like to start the function in a thread so that the UI will not be locked up but everytime I call InsertCursor, for example, arcpy.InsertCursor(self.featureClassList[5]) within a Thread I get a catastrophic crash...  Is this an impossible task?
T
moriapedhazur
Encountered the same problem, any answer?
by Anonymous User
Not applicable
ArcGIS Classes (Featureclass, Layers, Fields, Maps, etc.,.) in arcpy do not play well with being transferred between python threads due to python's pickling. I haven't met anyone yet that has created their own pickling class to transfer the esri classes either. I think if you can figure out how to pickle the arcpy data class being transferred, you'll be able to get closer to a solution.
