Adding a button to dgrid
5012
5
02-18-2014 06:27 AM
MichelleRogers1
Hi all. I am trying to add a button to the dgrid so that the user sees a magnifying glass instead of the objectid, since I don't want the end-user to see the objectid. I tried adding the following code:
window.grid = new (declare([Grid, Selection]))({
// use Infinity so that all data is available in the grid
 bufferRows: Infinity,
 columns: {
  "id": {"label": "ID", "formatter": makeZoomButton},
  "vehicleId": "Vehicle ID",
  "velocity": { "label": "Speed (MPH)", "formatter": dojoNum.format },
  "timestamp": {"label": "Last Contact", "formatter": formatTimestamp}
}, "grid");
function makeZoomButton(e){
 zBtn = "<div data-dojo-type = 'dijit/form/Button'><img src='images/zoom.png'";
 zBtn = zBtn + "width='14' height='14'";
 zBtn = zBtn + "onClick=\"selectUnit('"+e+"')\"></div>";
 return zBtn
I already had this existing code for zooming to the feature:
grid.on(".field-id:click", selectUnit);
function selectUnit(e) {
 // select the feature
 var flzoom = map.getLayer("units");
 var query = new Query();
 query.objectIds = [parseInt(e.target.innerHTML)];
 flzoom.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(result) {
  if ( result.length ) {
   point = result
   // re-center the map to the selected feature
   window.map.centerAndZoom(result[0].geometry, 100);
   } else {
   console.log("Feature Layer query returned no features... ", result);
The existing code works when the id field doesn't have a formatter, but when I insert the formatter, the grid still shows up, but when I try to click on the magnifying glass, it gives this error: SCRIPT5009: 'selectUnit' is undefined
Any help is greatly appreciated, thanks!
Michelle
KenBuja
MVP Esteemed Contributor
I'm still trying to see how to make it work with a Button, but I have gotten it working with an image. I took the dgrid sample and put a image in the ID field. You can see it here. Click on the Zoom image to make it highlight the selected state.
KenBuja
Take a look at this post in GIS.StackExchange. Instead of using the formatter, it uses renderCell to put a button in a cell.
MichelleRogers1
I looked at that post, and did what it said, but there is no button showing up at all.  I am new with the ArcGIS API, so any detailed help or examples on how to do this would be appreciated.
Thanks!
KenBuja
MichelleRogers1
This worked, thanks so much!
KenBuja
And here's a version that put a button in the dGrid to zoom.
