Install Javascript API - error
891
02-10-2014 07:00 AM
CliveSwan
The Javascript API installation file instructs:
Replace '[HOSTNAME_AND_PATH_TO_JSAPI]' with the following "<myserver>/arcgis_js_api/library/3.1/jsapi/"
I am testing a virtual Machine .
I replaced with the Virtual machine path <test.NRT.int> : test.NRT.int/arcgis_js_api/library/3.1/jsapi/
I get an error "file not found"
Any suggestions to solve this problem???
Thanks for your assistance.
RobertoPepato
Hello Clive,
Did you prefixed your uri with the protocol specification (e.g. "http/https")? The paths on your web server are ok?
Do you have any requirement that blocks you from download the api file from the internet? If not, I recommend you getting the latest version from esri CDNs:
<script src="https://js.arcgis.com/3.8/"></script>
