add a vertex to multiple polylines
3400
02-04-2014 07:31 AM
deleted-user-MS0lE1F_0-sy
I have a lot of lines in a feature class where the only vertices are the two end points.  I want to add one vertex 2 ft from the start point of the line.  I might be doing something wrong, but the Densify tool doesn't seem like it can pull this off.  Any suggestions would be very helpful.
Thank you,
Matt
FilipKrál
Hi Matt,
How about something like the code below.
It assumes projected coordinate system and that all your lines are longer than the shift_by distance.
You might need to fix a row or two though cause I haven't tested exactly these lines.
Hope this helps.
Filip.
in_fc = r'c:\temp.gdb\infc' out_fc = r'c:\temp.gdb\outfc' shift_by = 2.0 # shift distance in linear units of your PROJECTED (!) coordinate system  import os, arcpy  def shiftPointInDirection(x, y, direction, shiftDistance):     """Return new (x, y) as shifted x, y in direction (dx, dy) by distance shiftDistance"""     d = (direction[0]**2 + direction[1]**2)**(0.5)     q = shiftDistance / d     x =  x + q * direction[0]     y = y + q * direction[1]     return (x, y)  # create a new polyline feature class and add field(s) out_fc = arcpy.CreateFeatureClass_management(os.path.dirname(out_fc), os.path.basename(out_fc), "POLYLINE", spatial_reference = arcpy.Describe(in_fc).spatialReference).getOutput(0) arcpy.AddField_management(out_fc, "ORIGID", "LONG")  # starting an edit session may not be necessary, but to stay on the safe side... with arcpy.da.Editor(workspace) as edit:      with arcpy.da.SearchCursor(in_fc, ["SHAPE@", "OID@"]) as sc:      with arcpy.da.InsertCursor(out_fc, ["SHAPE@", "ORIGID"]) as ic:       for row in sc:                  # if your geometries are simple 2D singlepart lines, something like this                 # should get the actual line vertices of a feature (sorry don't have Arc now to test)                 # search Reading Geometries and Writing Geometries in help        shp = row[0].getPart(0)                  # handle individual vertices                 p0 = shp.firstPoint                 p2 = shp.lastPoint                 x1,y1 = p0.X, p0.Y                 shift_dir = (p2.X - p0.X, p2.Y - p0.Y)                 x1,y1 = shiftPointInDirection(x1, y1, shift_dir, shift_by)                 p1 = arcpy.Point(x1, y1)                  # create new feature and store it                 new_geometry = arcpy.Polyline(arcpy.Array([p0, p1, p2]))                 new_row = [new_geometry, row[1]]                 ic.insertRow(newrow)  # then join attributes from in_fc to out_fc on in_fc.OBJECTID = out_fc.ORIGID
FilipKrál
Hi Matt,
Hope this helps.
Filip.
Thank you Filip, this looks great.  I will test it out as soon as I get the chance.  Thank you for your help, I will let you know if it works out.  Matt
I had to tweak it a little.  Three things to note:  arcpy.CreateFeatureclass - lower case c @ (C)lass, had to drop getValue(0) from shp to get it to work(?), and had to define the firstPoint/lastPoint before using that to define p0/p2(not sure that was necessary).
Thanks again!!
import os, arcpy
in_fc = arcpy.GetParameterAsText(0)
    return (x, y)
out_fc = arcpy.CreateFeatureclass_management("Y:/GIS/Working/Test", "test.shp", "POLYLINE", spatial_reference = arcpy.Describe(in_fc).spatialReference).getOutput(0)
workspace = os.path.dirname(in_fc)
      for row in sc:
       shp = row[0]
       firstPoint = shp.firstPoint
       lastPoint = shp.lastPoint
       p0 = firstPoint
       p2 = lastPoint
       x1,y1 = p0.X, p0.Y
       ic.insertRow(new_row)
