GraphicsLayer click event to obtain multiple graphics
1885
02-03-2014 03:26 PM
KarenRobine
I've added a click event to a GraphicsLayer that has graphics from X/Y locations unrelated to Feature Layers. However, I've noticed that it's only showing a single graphic at a time. I basically need to select multiple graphics within an extent. The QueryTask forces me to point to a URL of a Feature Layer. But I don't have a Feature Layer; I only have Graphics. What gives? How can I select multiple graphics from a single Graphicslayer when the user clicks on a map? Feel like I'm missing something simple here.
KaitlynnDavis
Have you taken a look at this sample? It shows you how to initialize a drawing toolbar that's capable of selecting graphics within a user-defined extent (see the code's "findPointsinExtent" function)
https://developers.arcgis.com/javascript/jssamples/graphics_extent_query.html
KarenRobine
Yes. I saw that after I posted:
        var results = [];
        dojo.forEach(map.graphics.graphics,function(graphic){
          if (extent.contains(graphic.geometry)) {
            graphic.setSymbol(highlightSymbol);
            results.push(graphic.getContent());
          //else if point was previously highlighted, reset its symbology
          else if (graphic.symbol == highlightSymbol) {
            graphic.setSymbol(defaultSymbol);
The only problem is that it loops through all of the graphics on the map. Could be slow as I may end up with thousands of graphics. But maybe the only possible solution?
KaitlynnDavis
It's very quick with several dozen graphics, but I've never used this selection method for more than that, so I can't say if it will be ok with several thousand. Maybe you could look into implementing graduated symbols for your graphics? https://developers.arcgis.com/javascript/jssamples/renderer_graduated_polygon.html
BrandonIves
Take a look at this one too:
https://developers.arcgis.com/javascript/jssamples/graphics_multiple_layers.html
