Combinig two map serices
637
01-28-2014 12:43 AM
vinayb
HI all,
  I want to combine two map serices , i have one map service which is map and other has some other service . I need to combine these and show on .I tried the following
map = new Map("MapSection", {
          extent: initExtent
          WorldCountries1 = new esri.layers.ArcGISDynamicMapServiceLayer("mpasericeurl1");
 map.addLayer(WorldCountries1);
  var WorldCountries = new ArcGISDynamicMapServiceLayer("arcgisUrl");
        //WorldCountries.setOpacity(0.75);
        console.log(" in map ");
        map.addLayer(WorldCountries);
  When i did that the first service is displaying behind the second service , i reversed the order in which i am adding layer but still issue persist what could be the better way to do this.
KenBuja
MVP Esteemed Contributor
If I am understanding your question correctly, you are trying to add the services in a particular order. Instead of using addLayer after declaring each layer variable, you can use addLayers to add them in any order you want.
var WorldCountries1 = new esri.layers.ArcGISDynamicMapServiceLayer("mpasericeurl1");
//map.addLayer(WorldCountries1);
//map.addLayer(WorldCountries);
map.addLayers([WorldCountries, WorldCountries1]);
//or map.addLayers([WorldCountries1, WorldCountries]);
