I am using the following ESRI libraries :
dojo.require("esri.map");
dojo.require("esri.layers.MapImage");
dojo.require("esri.layers.MapImageLayer");
dojo.require("esri.geometry.Extent");
dojo.require("esri.SpatialReference");
dojo.require("esri.dijit.HomeButton");
dojo.require("esri.dijit.LocateButton");
dojo.require("esri.InfoTemplate");
dojo.require("esri.layers.FeatureLayer");
dojo.ready(init);
I am getting this error : "Uncaught TypeError: Cannot call method 'insertBefore' of null", when I run the code. The error occurs in "init.js" method of ESRI.
The code works fine when do not use the feature layer and comment it out.
The error only occurs in particular systems, and the code works fine in other system.
This is very confusing. Could anyone point what I am missing out.
Thanks in advance.
