Highlighting a point feature based on a query without overriding style
1373
01-08-2014 11:36 AM
BrettGreenfield__DNR_
I'm creating a simple map filled with point features of businesses.  Users can click on a point to get information on it, or click on the name of the business in a dGrid which fires a query and selects the appropriate feature.  If a user clicks a point on the map, the default light-blue box with tick marks surrounds the feature to highlight it.  If they click a business name, no highlight graphic is applied.  I got around this issue by setting a selection symbol; however, now if a user clicks a point on the map, both the default box with tick marks AND the selection symbol is added to the map; and if you click an item in the dGrid, only the highlight symbol is applied and it overrides the default style of the feature (which is a problem as the points are colored differently).  If I set the opacity of the fill-color to 0, only the light-blue outline shows up - no fill color at all (not even the fill color of the actual feature).  Try my code below to see an example of what's happening.
<!DOCTYPE html> <html> <head>   <meta charset="utf-8">   <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">   <title>True Blue Program Participants</title>    <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/dojo/dojo/resources/dojo.css">   <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/dgrid/css/dgrid.css">   <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/dgrid/css/skins/tundra.css">   <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/dojo/dijit/themes/tundra/tundra.css">   <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/esri/css/esri.css">   <style>     html, body {        height: 100%;        width: 100%;        margin: 0;        padding: 0;        overflow: hidden;     }  td  {  padding:3px;  }     #BasemapToggle {       position: fixed;       top: 3%;       right: 20px;       z-index: 50;     }      #container {        height: 100%;        visibility: hidden;     }     #bottomPane { height: 200px; }     #grid { height: 100%; }     .dgrid { border: none; }  .dgrid-column-Email {    width: 26%;  }  .dgrid-column-MaxSize {    width: 6%;  }  .dgrid-column-Phone {    width: 6%;  }     td.field-id { cursor: pointer;     text-decoration:underline;    color:blue;  }   </style>    <script src="http://js.arcgis.com/3.7/"></script>   <script>     require([       "dojo/ready",       "dgrid/OnDemandGrid",       "dgrid/Selection",        "dojo/store/Memory",        "dojo/_base/array",       "dojo/dom-style",       "dijit/registry",       "esri/map",        "esri/layers/FeatureLayer",    "esri/dijit/Legend",       "esri/tasks/QueryTask",       "esri/tasks/query",    "esri/dijit/BasemapToggle",       "dojo/_base/declare",        "dojo/number",        "dojo/on",        "dojo/parser",        "dijit/layout/BorderContainer",        "dijit/layout/ContentPane"       ], function(         ready,         Grid,          Selection,          Memory,          array,         domStyle,         registry,         Map,         FeatureLayer,         Legend,         QueryTask,         Query,   BasemapToggle,         declare,          dojoNum,          on,          parser       )   {         ready(function() {            parser.parse();            // create the dgrid           window.grid = new (declare([Grid, Selection]))({             bufferRows: Infinity,             columns: {               "id": "Business Name",               "Address": "Address",      "City": "City",      "State": "State",      "Zip": "Zip Code",      "Type": "Business Type"             }           }, "grid");            grid.on(".field-id:click", selectParticipant);            window.map = new Map("map", {             basemap: "streets",             center: [-76.5, 38.9],             zoom: 8           });          var toggle = new BasemapToggle({    map: map,    basemap: "satellite"     }, "BasemapToggle");     toggle.startup();                window.trueblueUrl = "http://services.arcgis.com/njFNhDsUCentVYJW/arcgis/rest/services/TrueBlueMap/FeatureServer/0";           window.outFields = ["Business_N", "Address", "City_1", "State", "Zip", "Type"];                var infoTemplate = new esri.InfoTemplate();           infoTemplate.setTitle("${Business_N}");     infoTemplate.setContent( "<table border='0', width='100%'>"          + "<tr><td width='50%' width='100%' valign='top'>Address:</td><td width='50%' valign='bottom'> ${Address}</td></tr>"          + "<tr><td width='50%' width='100%' valign='top'>City:</td><td width='50%' valign='bottom'> ${City_1}</td></tr>"          + "<tr><td width='50%' width='100%' valign='top'>State:</td><td width='50%' valign='bottom'> ${State}</td></tr>"          + "<tr><td width='50%' width='100%' valign='top'>Zip:</td><td width='50%' valign='bottom'> ${Zip}</td></tr>"          + "<tr><td width='50%' width='100%' valign='top'>Business Type:</td><td width='50%' valign='bottom'> ${Type}</td></tr>"          + "</table>"     );                   map.infoWindow.resize(425,150);          var highlight = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE, 12, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([0,255,255]), 3), new dojo.Color([50,50,255,1]));                     var fl = new FeatureLayer(window.trueblueUrl, {             id: "participants",             mode: esri.layers.FeatureLayer.MODE_ONDEMAND,             outFields: window.outFields,    infoTemplate: infoTemplate           });          fl.setSelectionSymbol(highlight);          fl.on("click", function(e) {       fl.clearSelection();    map.graphics.clear();    map.graphics.add(new esri.Graphic(e.graphic.geometry, highlight));    grid.clearSelection();     });            fl.on("mouse-over", function() {             map.setMapCursor("pointer");           });           fl.on("mouse-out", function() {             map.setMapCursor("default");           });      dojo.connect(map.infoWindow, "onHide", function() {    map.graphics.clear();    });                 map.addLayers([fl]);               map.on("load", function( evt ){             domStyle.set(registry.byId("container").domNode, "visibility", "visible");             populateGrid(Memory);           });            function populateGrid(Memory) {             var qt = new QueryTask(window.trueblueUrl);             var query = new Query();    bType = document.getElementById("businessFilter").value;             query.where = "Type LIKE '%" + bType + "%'";             query.returnGeometry = false;             query.outFields = window.outFields;             qt.execute(query, function(results) {               var data = array.map(results.features, function(feature) {                 return {                   "id": feature.attributes[window.outFields[0]],                   "Address": feature.attributes[window.outFields[1]],       "City": feature.attributes[window.outFields[2]],       "State": feature.attributes[window.outFields[3]],       "Zip": feature.attributes[window.outFields[4]],       "Type": feature.attributes[window.outFields[5]]                 }               });               var memStore = new Memory({ data: data });               window.grid.set("store", memStore);             });           }           // fires when a row in the dgrid is clicked           function selectParticipant(e) {       map.infoWindow.hide();             var fl = map.getLayer("participants");             var query = new Query();             businessName = (e.target.innerHTML);    query.where = "Business_N = " + "'" + businessName.replace("'", "''") + "'";               fl.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(result) {               map.centerAt(result[0].geometry);      result[0].getDojoShape().moveToFront();             });             }       document.getElementById("businessFilter").onchange = function (businessTypeQuery) {       businessType = document.getElementById("businessFilter").value;    fl.setDefinitionExpression("Type LIKE'%" + businessType + "%'")    populateGrid(Memory);    map.graphics.clear();     };             }       );     });   </script> </head>  <body class="tundra">   <div id="container" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design: 'headline', gutters: false, design: 'sidebar', liveSplitters:true">     <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region: 'center', splitter:true" style="z-index:2">    <span id="BasemapToggle"></span>    <span id="Filter" style="position:fixed; left:4.5%; top:2.1%; background-color:#FFFFFF; border:2px solid #666666; border-radius:6px; font-size:18px"><table id="filterTable", border='0', width='100%'><tr><td>Sort by:</td><td><select id='businessFilter' onchange="businessTypeQuery(this.value)"><option value='''>All Business Types</option><option value='Carry Out'>Carry Out</option><option value='Caterer'>Caterer</option><option value='Distributor'>Distributor</option><option value='Food Truck'>Food Truck</option><option value='Institutional'>Institutional</option><option value='Restaurant'>Restaurant</option><option value='Retail'>Retail</option><option value='Wholesale'>Wholesale</option></td></tr></table></span>  </div>     <div id="bottomPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region: 'bottom', splitter:true"> <div id="grid"></div>     </div>   </div> </body> </html>
Ultimately I'd like to have the same selection symbol applied whether a user clicks a point on the map or selects an item from the dGrid.  And I definitely just want a highlight around the point - I'd like the fill color of the original feature to remain even when selected.  I'm sure this is something simple, but I'm not finding it!
JianHuang
When you set selectionSymbol, that means when the feature is selected, this symbol will 'replace' the original symbol, instead of overlay on top of it.
You need to create a new graphic with the same geometry and the hightlight symbol, and add it to the map.graphics layer to achieve the visual effect.
JianHuang
Thanks - that totally solved my issue.
