Validation: attribute 'data-dojo-type' is not a valid attribute of element 'button'
3920
11
01-03-2014 08:06 AM
ShaningYu
Honored Contributor
Got several warnings on <button ... > <div ... >, etc., such as:
attribute 'data-dojo-props' is not a valid attribute of element 'button'
attribute 'data-dojo-type' is not a valid attribute of element 'div'
attribute 'data-dojo-props' is not a valid attribute of element 'div'
How can those problems be handled?  Thanks.
JonathanUihlein
Great!
Those errors should go away when you change the doctype of your webpage to the HTML5 standard:
<!DOCTYPE html>
ShaningYu
Honored Contributor
Referring the thread at http://forums.arcgis.com/threads/12911-Warnings-why, I did
<%--<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">--%>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
Namely, change to 4.01.  The warning messages were gone.  Thanks.
JonathanUihlein
I believe 'data-*' is a valid property on HTML5 elements.
Is your webpage in HTML5?
Read more here about Dojo-specific data props:
http://www.sitepen.com/blog/2012/01/19/html5-data-dojo-attribute-support/
Read more about HTML5 data props:
http://ejohn.org/blog/html-5-data-attributes/
*edit
You posted while I was posting; my suspicion was correct 😃
Is there any reason you aren't using HTML5?
ShaningYu
Honored Contributor
Ideally, I should use HTML5.  I need investigate more.  Thanks for you to remind me.  I have turned he Q as not answered.
JonathanUihlein
Great!
<!DOCTYPE html>
ShaningYu
Honored Contributor
Changed to
<!DOCTYPE html>
still shows not a valid attribute.
JonathanUihlein
Interesting! What browser and what specific version are you using?
ShaningYu
Honored Contributor
Run in IE 8
SteveCole
Honored Contributor
Given that IE-8 scores a whopping 43 out of a possible 555 points on http://html5test.com/ maybe that's the problem right there?
JonathanUihlein
Indeed.... I'm not sure those warnings will ever go away when viewing your web application in IE8.
