Show infoTemplate Programitically Feature Layer
4047
9
12-12-2013 04:48 AM
vinayb
HI All,
  I don't want to assign infoTemplate when initializing Feature Layer. Since i want to define on-click behavior for feature layer and i am not show Pop up each time hence How can i show Pop up i.e infoTempalte Programitically.
TyroneLigon
Which version of the JavaScript API are you using? If I'm not mistaken, if you're using version 3.3 or earlier you have to include a reference to Popup.css in your page, otherwise the popup window will always open in the upper left hand corner of the map.
ReneeMaxwell
This is how I accomplish this action, using the Identify Task:
// Function to format info window content based on feature attributes
function featureContent(feature) {
       var type = feature.attributes["TYPE"];
       var notes = feature.attributes["NOTES"];
       var baseContent = "<strong>Type:</strong> " + type;
       if (notes) { baseContent += "<br/><strong>Info:</strong> <span class='data'>" + notes + "</span>"; }
       return baseContent;
var idTask = new IdentifyTask(mapUrl);
var idParams = new IdentifyParams();
idParams.returnGeometry = true;
idParams.layerIds = [56, 59];
idParams.layerOption = IdentifyParams.LAYER_OPTION_TOP;
idParams.tolerance = 5;
function infoTask(evt) {
       idParams.geometry = evt.mapPoint;
       idParams.width = map.width;
       idParams.height = map.height;
       idParams.mapExtent = map.extent;
       idTask.execute(idParams, function (idResults) {
           if (idResults[0]) {
               array.forEach(idResults, function (result) {
                    var selFeature = result.feature;
                    map.infoWindow.setTitle(result.layerName);
                    var content = featureContent(selFeature);
                    map.infoWindow.setContent(content);
                    map.infoWindow.show(evt.mapPoint);
        }, null);
on(map, "click", infoTask);
vinayb
The problem is i don't want to define on-click functionality on map object i want to define on click functionality on feature Layer object .
is there any way i can show Infotemplate on the fly i am trying
as below
function getData(evt){
        try {
  require(["esri/InfoTemplate"], function(InfoTemplate){
    var graphic = evt.graphic;
    var countryName = evt.graphic.attributes.CNTRY_NAME;
    var template=new  InfoTemplate();
                          console.log(" got countryName" + countryName);
                          var alertDetailUrl = getAlertDetailsUrl(countryName);
                          console.log(" alertDetailUrl " + alertDetailUrl);
                          dojo.xhrGet({
                              url: alertDetailUrl,
                              handleAs: 'json',
                              load: function(data){
                                  console.log("data ");
                                  var popUpData = getPopUpContent(data);
                                  template.setTitle(countryName);
                                  template.setContent(popUpData);
     graphic.setInfoTemplate(template);
     map.graphics.add(graphic);
     graphic.show();
                                  console.log(" complete ");
                              error: dojo.hitch(this, "failure")
          catch (e) {
              console.log("error occured " + e);
ReneeMaxwell
You should be able to do that, similar to the map click event but use the feature layer onclick event instead.
on(featureLayerInstance, "click", function (evt) {
        dojo.xhrGet({
              handleAs: 'json',
              //You don't needto add the graphic to the map unless you want to give it a new selection symbol.
       //map.graphics.add(graphic);
       //graphic.show();
vinayb
unfortunately it does not work, it adds infotemplate first time next time you click it show infotemplate but position is not proper
ReneeMaxwell
You will need to reconfigure your code to incorporate part of the code I originally posted, so that the infoWindow is positioned according the evt mapPoint. Something like so:
        dojo.xhrGet({
              handleAs: 'json',
                  map.infoWindow.setTitle(countryName);
                  map.infoWindow.setContent(popUpData);
vinayb
Thanks , it work  but placement of infowindow is not proper.if I click on india popup shows in  Europe .
vinayb
Any other work around
TyroneLigon
vinayb
Awesome thanks this resolved but I am using 3.6
