adding wms Layer as a Basemap instead of using arcgis javascript api base maps
3665
12-11-2013 09:54 AM
GaneshSolai_Sambandam
HI GIS folks
I have an WMS layer which is a cross domain resource and I wanted to embed those layers as basemap in application using JavaScript api rather than using built in ArcGIS Basemaps.
here is the WMS Layer link:
http://geobretagne.fr/geoserver/ref/wms?service=WMS&request=getCapabilities
any help in this regard would be much appreciated.
ganesh
HI Guys
Could anyone please hlep or throw some insights on this.
ganesh
Hi GiS folks
Can you anyone help me adding this arcgis.com webmap  below into the arcgis javascript api.
For some reasons, I used the webmapid for this service but, it didn't work.
http://www.arcgis.com/home/item.html?id=536bb8b3c8a9418c938491752231d7f4
My script
[HTML]<!DOCTYPE html>
<html>
  <head>
    <title>Create web map from id</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/esri/css/esri.css">
    <link rel="stylesheet" href="css/layout.css">
    <script src="http://js.arcgis.com/3.7/"></script>
    <script>
      require([
        "dojo/parser",
        "dojo/ready",
        "dijit/layout/BorderContainer",
        "dijit/layout/ContentPane",
        "dojo/dom",
        "esri/map",
        "esri/urlUtils",
        "esri/arcgis/utils",
        "esri/dijit/Legend",
        "esri/dijit/Scalebar",
        "dojo/domReady!"
      ], function(
        parser,
        ready,
        BorderContainer,
        ContentPane,
        dom,
        Map,
        urlUtils,
        arcgisUtils,
        Legend,
        Scalebar
        ready(function(){
        parser.parse();
        arcgisUtils.createMap("536bb8b3c8a9418c938491752231d7f4","map").then(function(response){
         // dom.byId("title").innerHTML = response.itemInfo.item.title;
        //  dom.byId("subtitle").innerHTML = response.itemInfo.item.snippet;
          var map = response.map;
          //add the scalebar
          var scalebar = new Scalebar({
            map: map,
            scalebarUnit: "english"
          //add the legend. Note that we use the utility method getLegendLayers to get
          //the layers to display in the legend from the createMap response.
         // var legendLayers = arcgisUtils.getLegendLayers(response);
          /*var legendDijit = new Legend({
            map: map,
            layerInfos: legendLayers
          },"legend");
          legendDijit.startup(); */
    </script>
  </head>
  <body class="claro">
    <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%;">
      <div id="header" class="shadow roundedCorners" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'">
        <div id="title"></div>
        <div id="subtitle"></div>
      </div>
      <div id="map" class="roundedCorners shadow" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"></div>
      <div id="rightPane" class="roundedCorners shadow" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'" >
        <div id="legend"></div>
      </div>
    </div>
  </body>
</html>
[/HTML]
