ArcGIS Online - Using Spatial Analysis Service From JS API
864
12-09-2013 05:22 PM
ShaunWeston
I'm trying to use one of the spatial analysis services from a javascript app I've built, but having some issues. I'd like to use this service:
https://developers.arcgis.com/en/rest/analysis/api-reference/find-hot-spots.htm
A
nd have a ArcGIS Online developer account. I basically have some code to request a token and send it with a featureset to this service and this is the reponse I get back from the service:
  1. inputs: {}
  2. jobId: "j8c0cb0dbe6814e5b9ec3b29e8885da8f"
  3. jobStatus: "esriJobFailed"
  4. messages: [{type:esriJobMessageTypeError,�?�},�?�]
    1. 0: {type:esriJobMessageTypeError,�?�}
      1. description: "{"messageCode": "AO_100007", "message": "FindHotSpots failed."}"
      2. type: "esriJobMessageTypeError"
    2. 1: {type:esriJobMessageTypeError, description:Failed to execute (FindHotSpots).}
      1. description: "Failed to execute (FindHotSpots)."
      3. 2: {type:esriJobMessageTypeError, description:Failed.}
        1. description: "Failed."
        3. results: {}
        4. it's pretty vague, so I don't where it's going wrong, whether my inputs are wrong or what?
          Anyone know?
          ShaunWeston
          Ok, so now I'm getting a different error:
          ERROR 000735: analysisLayer: Value is required
          Also, with this sample:
          http://developers.arcgis.com/en/javascript/samples/analysis_hotspot/
          I
          've tried with a couple of accounts (a developer account and an ArcGIS for organisations account) and it didn't work, then I tried with another account (another ArcGIS for organisations account) and it did work, so pretty confused how to use these services.
          ShaunWeston
          Ok managed to get this to work. It was a combination of things that was causing it to not work correctly.
          I've managed to create a feature collection, load in the features to be analysed to this feature collection and send it to the service. Then I get a feature collection back and can add that to the map, so had to write a bit of code to get that to work.
