IE 10 navigation toolbar issue
5854
15
12-02-2013 07:02 AM
JennyHe
The zoom box (black background with red outline) doesn't show in IE 10 for the zoom-in and zoom-out tools in this following link:
http://developers.arcgis.com/en/javascript/samples/toolbar_navigation/. It works fine for Chrome and Firefox.
Could anybody please look into this issue? Thanks!
JonathanUihlein
It will be fixed in the upcoming 3.12 3.11 release (this week or next).
I just double checked and it is working in the new version for IE10.
SubaKrishnan
Its a bug, and the dev team is currently working on it.
Thanks!
CoreyAlix
This can still be reproduced in IE 11 using this sample:
Navigation toolbar
JennyHe
Thank you for your reply, Suba.
KenDoman
If it's any help, using Shift+mouse drag any time before calling navToolbar.activate shows the graphic on zoom-in. Once the navToolbar.activate is called, even Shift + mouse drag doesn't show the graphic.
ScottGunn
I have confirmed this issue in IE11.0.3 as well.  Zoom boxes work fine in Chrome\FF.
Thanks for your hard work.
ØyvindIdland
I can confirm that this is still an issue in V3.9 of the API.
- oyvind
CoreyAlix
From ESRI support:
"I found this zoom-in red box not show in IE 10/11 issue has already been assigned a bug in our system and I have assigned this case to this bug on your behalf. [#NIM098054 The red zoom box does not display in an ArcGIS API for JavaScript application.] This issue will be fixed in ArcGIS JavaScript 4.0"
JonathanUihlein
CoreyAlix
http://js.arcgis.com/3.11/dojo/dojo.js does not have the "js/dojo" that 3.10 has (http://js.arcgis.com/3.10/js/dojo/dojo/dojo.js). Is it safe to assume "js/dojo" will be dropped?
