Can you post your revised code?This works for me<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Map with legend</title> <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/esri/css/esri.css"> <style> html, body { height: 97%; width: 98%; margin: 1%; } #rightPane { width: 20%; } #legendPane { border: solid #97DCF2 1px; } .esriLegendServiceLabel { /*visibility: hidden;*/ display: none; } .esriLegendLayerLabel { /*visibility: hidden;*/ /*display: none;*/ } .esriLegendLeft { padding-left: 0px; } </style> <script src="http://js.arcgis.com/3.7/"></script> <script> var map; require([ "esri/map", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/layers/FeatureLayer", "esri/dijit/Legend", "dojo/_base/array", "dojo/parser", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/layout/AccordionContainer", "dojo/domReady!" ], function ( Map, ArcGISDynamicMapServiceLayer, FeatureLayer, Legend, arrayUtils, parser ) { parser.parse(); map = new Map("map", { basemap: "topo", center: [-117.4408, 33.4419], zoom: 9 }); var dynamicLayer = new ArcGISDynamicMapServiceLayer("http://www.sawpa.net/arcgissawpa/rest/services/CEDEN_TMDL/MapServer", { }); var featureLayer = new FeatureLayer("http://www.sawpa.net/arcgissawpa/rest/services/CEDEN_TMDL/MapServer/0", { }); //add the legend map.on("layers-add-result", function (evt) { var layerInfo = arrayUtils.map(evt.layers, function (layer, index) { return { layer: layer.layer, title: layer.layer.name }; }); if (layerInfo.length > 0) { var legendDijit = new Legend({ map: map, layerInfos: layerInfo }, "legendDiv"); legendDijit.startup(); } }); map.addLayers([dynamicLayer]); }); </script> </head> <body class="claro"> <!--[if IE 7]> <style> html, body { margin: 0; } </style> <![endif]--> <div id="content" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:true" style="width: 100%; height: 100%; margin: 0;"> <div id="rightPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'"> <div data-dojo-type="dijit/layout/AccordionContainer"> <div data-dojo-type="dijit/layout/ContentPane" id="legendPane" data-dojo-props="title:'Legend', selected:true"> <div id="legendDiv"></div> </div> <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="title:'Pane 2'"> This pane could contain tools or additional content </div> </div> </div> <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" style="overflow: hidden;"> </div> </div> </body> </html>
