Portal getFolders not returning root folder
1178
11-22-2013 01:08 PM
BillGrow
While retrieving portal items through the API, using loggedInUser.getFolders() then looping through those folders with loggedInUser.getItems(folder.id), I've noticed I dont get any items that are in the root (Home) folder, ie. items not in a folder.
The "Home" folder does not appear to be in the .getFolders() response, so I am wondering how I find this ID to get it's items.
~Bill
JianHuang
You are right, getFolders() doesn't return the root folder.
You can fetch the root folder by using the URL directly. For example, the following code snippet shows how to add an item to the root folder.
var userContentUrl = user.portal.url + "/content/users/" + user.credential.userId,
  folderUrl;
if ("Want to save to the root folder") {
          folderUrl = userContentUrl;
        } else {
          folderUrl = userContentUrl + "/" + folderId;
var request = esri.request({
          url: folderUrl + "/addItem",
          content: item
          usePost: true
        request.then(requestSucceeded);
