change renderer for dynamic map service
1201
11-19-2013 04:49 PM
FangmingDu
Hello Everyone and ESRI,
I'm trying to change the symbology of a dynamic map layer. It already has the GenerateRendererTask enabled.
And actually, I got the renderer object back from GenerateRendererTask, but the color of the map does not change...
In the renderer object, there is one field "_symbols", it has all the class breaks and symbol object (including color,style,type). I applied this renderer object to the dynamic map layer using following code
app.map.getLayer("som_map").setLayerDrawingOptions(optionsArray);
app.map.getLayer("som_map").show();
Does anyone have any ideas about this?
What else I need to check? or Is there any way I can troublshoooooting this?
UPDATE:
Compared to the renderer object from (http://developers.arcgis.com/en/javascript/sandbox/sandbox.html?sample=renderer_dynamic_layer_change...) which works,
I found in my renderer object, it does not have the field "_inherited"...which seems to have a few functions inside. That is probably the problem. But I have no idea about why this happened?????????
BjornSvensson
Esri Alum
What version is your server?
"The GenerateRendererTask is available for map service or tables that support the generateDataClasses operation (version 10.1 or greater)."
https://developers.arcgis.com/en/javascript/jsapi/generaterenderertask.html
FangmingDu
Thanks for the reply. I'm using ArcGIS server 10.1. I'm pretty sure it supports generate renderer task, because I can even see it while accessing from http://192.168.2.5:6080/arcgis/rest/services/fangming/SOM_DynamicMap/MapServer/0
I'm using the same code in Javascript from the sample.
var classDef = new ClassBreaksDefinition();
   classDef.classificationField = "attr1";
      classDef.classificationMethod = "natural-breaks"; // always natural breaks
      classDef.breakCount = 5; // always five classes
      classDef.baseSymbol = app.sfs;
      var colorRamp = new AlgorithmicColorRamp();
      colorRamp.fromColor = new Color.fromHex("#ffffcc");
      colorRamp.toColor = new Color.fromHex("#006837");
      colorRamp.algorithm = "hsv"; // options are:  "cie-lab", "hsv", "lab-lch"
      classDef.baseSymbol = new SimpleFillSymbol("solid", null, null);
      classDef.colorRamp = colorRamp;
      var params = new GenerateRendererParameters();
      params.classificationDefinition = classDef;
      console.dir("classDef");
      console.dir(classDef);
      var generateRenderer = new GenerateRendererTask("http://192.168.2.5:6080/arcgis/rest/services/fangming/SOM_DynamicMap/MapServer/0");
      generateRenderer.execute(params, applyRenderer, errorHandler);
    function applyRenderer(renderer) {
        console.dir(JSON.stringify(renderer));
          var optionsArray = [];
          var drawingOptions = new LayerDrawingOptions();
          drawingOptions.renderer = renderer;
          optionsArray[2] = drawingOptions;
          basemap.setLayerDrawingOptions(optionsArray);
          basemap.show();
Then I printed out the renderer object as following:
{"breaks":[[0.00215526,0.0100578],[0.0100578,0.0181308],[0.0181308,0.0302279],[0.0302279,0.0463656],[0.0463656,0.0627432]],"_symbols":{"0.00215526-0.0100578":{"type":"simplefillsymbol","style":"solid","color":{"r":255,"g":255,"b":204,"a":1}},"0.0100578-0.0181308":{"type":"simplefillsymbol","style":"solid","color":{"r":184,"g":217,"b":130,"a":1}},"0.0181308-0.0302279":{"type":"simplefillsymbol","style":"solid","color":{"r":97,"g":179,"b":72,"a":1}},"0.0302279-0.0463656":{"type":"simplefillsymbol","style":"solid","color":{"r":28,"g":142,"b":45,"a":1}},"0.0463656-0.0627432":{"type":"simplefillsymbol","style":"solid","color":{"r":0,"g":104,"b":55,"a":1}}},"infos":[{"classMaxValue":0.0100578,"label":"0.00216 - 0.01006","description":"","symbol":{"type":"simplefillsymbol","style":"solid","color":{"r":255,"g":255,"b":204,"a":1}},"minValue":0.00215526,"maxValue":0.0100578},{"classMaxValue":0.0181308,"label":"0.01007 - 0.01813","description":"","symbol":{"type":"simplefillsymbol","style":"solid","color":{"r":184,"g":217,"b":130,"a":1}},"minValue":0.0100578,"maxValue":0.0181308},{"classMaxValue":0.0302279,"label":"0.01814 - 0.03023","description":"","symbol":{"type":"simplefillsymbol","style":"solid","color":{"r":97,"g":179,"b":72,"a":1}},"minValue":0.0181308,"maxValue":0.0302279},{"classMaxValue":0.0463656,"label":"0.03024 - 0.04637","description":"","symbol":{"type":"simplefillsymbol","style":"solid","color":{"r":28,"g":142,"b":45,"a":1}},"minValue":0.0302279,"maxValue":0.0463656},{"classMaxValue":0.0627432,"label":"0.04638 - 0.06274","description":"","symbol":{"type":"simplefillsymbol","style":"solid","color":{"r":0,"g":104,"b":55,"a":1}},"minValue":0.0463656,"maxValue":0.0627432}],"attributeField":"attr1","classificationMethod":"natural-breaks","isMaxInclusive":true}
