I'm in the process of creating a web editing application by modifying some of the javascript examples. I have added LocateButton into the app however when I click on the button it just spins. It's not my browser because the examples work just fine. Here is my code: <script>
require([
"dojo/ready",
"dojo/parser",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"esri/map",
"esri/dijit/LocateButton",
"esri/config",
"esri/tasks/GeometryService",
"esri/urlUtils",
"esri/arcgis/utils",
"dojo/dom",
"dojo/_base/array",
"esri/dijit/editing/Editor",
"dojo/domReady!"
], function(
ready,
parser,
BorderContainer,
ContentPane,
Map,
LocateButton,
config,
GeometryService,
urlUtils,
arcgisUtils,
dom,
array,
Editor
ready(function(){
parser.parse();
config.defaults.io.proxyUrl = "/proxy";
config.defaults.geometryService = new GeometryService("http://maps.ci.perrysburg.oh.us/arcgis/rest/services/Utilities/Geometry/GeometryServer");
//check to see if a webmap was specified using URL params. If not use the
//hardcoded webmap id
var urlObject = urlUtils.urlToObject(document.location.href);
var webmap = "90d7e213fb014d31ac623d233511fcf9";
if(urlObject.query && urlObject.query.webmap){
webmap = urlObject.query.webmap;
//create the map
arcgisUtils.createMap(webmap, "map", {
mapOptions: {
sliderStyle: "large"
ignorePopups: true
}).then(function(response){
var map = response.map;
dom.byId("title").innerHTML = response.itemInfo.item.title;
dom.byId("snippet").innerHTML = response.itemInfo.item.snippet;
geoLocate = new LocateButton({
map: map,
geolocationOptions: {
maximumAge: 0,
timeout: 15000,
enableHighAccuracy: true
}, "LocateButton");
//create the editor widget
var layerInfo = [];
var layers = response.itemInfo.itemData.operationalLayers;
array.forEach(layers, function (layer){
layerInfo.push({
"featureLayer": layer.layerObject
var settings = {
map: map,
layerInfos: layerInfo
var editorWidget = new Editor({
settings: settings
},"editorDiv");
editorWidget.startup();
</script>
Any help would be much appreciated!Thank you,Ian
