What happens when another function is inside require([ ],function( ));
932
10-29-2013 10:54 AM
LeiZhou
In AMD style codes, I don't understand what happens when a function is in inside the require([...], function() {}); for example, the following codes:
require([...], function() { .....  function ABC () {a = c + b; } ..... });
The function ABC is very confusing to me.  When the program runs, when will function ABC be executed?  To understand this, should I go study more dojo language? Thanks a lot!
ReneRubalcava
Esri Frequent Contributor
The ABC function lives in the scope of the require() function, but isn't executed unless you call it in the require function. It is only accessible inside that particular require function. This isn't really a Dojo specific issue. Modules simply scope functionality. But when you define() a module, unless you return something, it doesn't provide anything. This is why you may come across errors like variable equals 3 or something odd, because maybe you forgot to place a return in the module.
To help illustrate, let's look at a define() module.
// ABCModule define([], function() {   function ABC (b, c) {     var a = c + b;     return a;   }    return ABC; // defined modules should return something, object or function. });  // Main JS file require(['./ABCModule'], function(ABC) {   ABC(1, 2); // returns 3; });
If you didn't actually return ABC in the defined module, you would never be able to use it, as it's not exposed to the outside world.
AMD modules essentially use the revealing module pattern to share their innards (or the important parts anyway) with the everyone else.
http://addyosmani.com/resources/essentialjsdesignpatterns/book/#revealingmodulepatternjavascript
http://requirejs.org/docs/whyamd.html#amd
Here are a couple of links that discuss scope.
http://dailyjs.com/2012/07/23/js101-scope/
https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Functions_and_function_scope
http://javascriptplayground.com/blog/2012/04/javascript-variable-scope-this/
Also, you typically only have a single require() per application, an entry point to start the application. This SO answer covers if pretty nicely.
http://stackoverflow.com/questions/11559270/what-is-the-main-difference-between-require-and-define-f...
Hope that helps a bit.
ReneRubalcava
LeiZhou
Thanks a lot! It is a very useful information.
