Using dojo FilteringSelect for text autocomplete
6688
8
10-28-2013 08:52 AM
GeoffSchwitzgebel
I am trying to implement text autocompleting within a dijit.form.FilteringSelect.  I have set up my query to return the appropriate values.  I have created a new mem store that is being populated correctly.  The issue I am running into is that the available names are not populating when the application is loaded.  I am getting "TypeError: a[this.searchAttr] is undefined" thrown back in firebug when I click on the dropdown arrow.  I have removed the query task URL since it is internal only.  Any assistance is appreciated.
Geoff
Here is my code:
      var queryTaskName = new esri.tasks.QueryTask("");                 //create an array                                 var locNames = [];                 locNamesMemory = new Memory({ data: locNames, idProperty: "NAME" });                 //build query filter                 var queryName = new esri.tasks.Query();                 queryName.returnGeometry = false;                 queryName.outFields = ["OBJECTID","NAME"];                 queryName.where = "OBJECTID > 0";                 queryName.returnGeometry = false;                 queryTaskName.execute(query, function (results) {                     //parse results and add to autocomplete widget                     dojo.forEach(results.features, function (value, index) {                         locNames.push(value.attributes.NAME);                     });                 }, function (error) {                     alert("Error: " + error);                 });                  var filteringSelect = new FilteringSelect({                     id: "txtSearch",                     name: "state",                     value: "Enter Name Here",                     store: locNamesMemory,                     autoComplete: true,                     searchAttr: ["NAME"]                 }, "txtSearch");
[HTML]<input id="txtSearch" type="text"  placeholder="Enter Name Here" >[/HTML]
JasonZou
Tracy is correct. I overlooked one thing in my revision.
Change:
To:
locNames.push({NAME: value.attributes.NAME});
SteveCole
Honored Contributor
I've used a FilteringSelect successfully but my coding is a little different. The javaScript code:
     //Push the list of road names into the combo box
     query = new esri.tasks.Query();
     query.where = "1=1";
     query.outFields = ["*"];
     query.returnGeometry = false;
     var queryTask = new esri.tasks.QueryTask(SERVERPATH);
     queryTask.execute(query,populateRdNameCbo);
     function populateRdNameCbo(results) {
 //Populate the dropdown list box with unique values
 values = [];
        testVals = {};
 features = results.features;
 dojo.forEach (features, function(feature) {
  curName = feature.attributes.FULLNAME;
  if (!testVals[curName]) {
   testVals[curName] = true;
   values.push({"OBJECTID":feature.attributes.OBJECTID,"RDNAME":feature.attributes.FULLNAME});
 dataItems = {
     identifier: "OBJECTID",
     label: "RDNAME",
     items: values
 theStore = new dojo.data.ItemFileReadStore({data:dataItems});
 dijit.byId("cboRdName").set("store", theStore);
My HTML for the combo box is:
[HTML]<input id="cboRdName" dojoType="dijit.form.FilteringSelect" searchAttr="RDNAME" name="WidgetName" pageSize="6" fetchProperties="{sort:[{attribute:'RDNAME', descending:false}]}" placeHolder="Select a road or start typing" onChange="updateCrossStreetList();closureProps['rdName'] = document.getElementById('cboRdName').value;closureProps['status'] ='CLOSED';zoomToRoad()"/>[/HTML]
This is using v3.4 of the API.
Steve
JasonZou
filteringSelect needs to be created inside the callback function of the query. Try to change your code as shown below.
                var filteringSelect;
                var locNames = [];
                queryTaskName.execute(queryName, function (results) {
                    // assume locNamesMemory is declared as a global variable.
                        autoComplete: true,
                        searchAttr: "NAME"
                    }, "txtSearch");
GeoffSchwitzgebel
Jason,
I tried making your changes as suggested but I am still having the same issue.
Geoff
JasonZou
Set a breakpoint right after filteringSelect is instantiated, and check filteringSelect.store to see if the data is populated. If yes, then something else in your code is wrong. From the original error:  "TypeError: a[this.searchAttr] is undefined", it's something to do with an array named "a". Can you post the code that relates to how "a" array is populated and being used?
TracySchloss
Honored Contributor
I don't see how Memory knows that NAME exists to serve as the idProperty.  If all you have is an array of names, where does it pick out anything called NAME?
I have a function that populates a filteriingSelect.  Maybe something in this will help you?
function populateResultsHandler(results){
    var select = registry.byId("pickSelect");//my filteringSelect dijit
    pickList.length = 0;
    var numResults = results.featureSet.features.length;
      for (var j = 0; j < numResults; j++) {
          var pickCode = results.featureSet.features.attributes[pickAttr];
        pickList.push({id: pickCode, label: pickCode});
      pickList.sort(function(item1, item2) {
        var label1 = item1.label.toLowerCase(),
        label2 = item2.label.toLowerCase();
        return (label1 > label2) ? 1 : (label1 < label2) ? -1 : 0;
   var dataStore = new Memory({data:pickList, idProperty:"id"});
    select.set ("searchAttr", "id");
    select.set("labelAttr", "id");
    select.set("store", dataStore);
Here's the HTML
         <select id="pickSelect" data-dojo-type="dijit/form/FilteringSelect"  placeHolder="Select a township"
         data-dojo-props="title:'Find points in selected township/range',maxHeight:200, size: 30, queryExpr:'${0}*', ignoreCase:true">
     </select>
JasonZou
Change:
To:
GeoffSchwitzgebel
Thanks everyone for your help!  I made Tracy's change to Jason's post and it's good to go. Steve, I did try yours out but I wasn't able to get it configured correctly.
Geoff
SteveCole
Honored Contributor
No worries! I had a little wonkty tidbit in my code since it's also trying to create a unique list for my filteringSelect. Glad you got it squared away!
